Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
kpfoten's Avatar
Removing reverse switch for engine drop
Hi,
I've got a '63 356B and I'm dropping the engine/trans. Was wondering how to remove the reverse-switch wires? I'm not sure if I have to remove the switch itself or if I can pull the wires out?
(I could remove the wires/connectors in my '77 911)
Any help would be great--thanks.
Kris - '77 911S
Old 03-21-2006, 05:38 PM
id10t's Avatar
Not sure about the trans removal, but when I pull the engine on my '65 C its just fuel line, regulator (since its mounted to the fw), and the 4 bolts.
Old 03-22-2006, 04:40 AM
kpfoten's Avatar
Thanks--which four bolts separate the trans from the engine? It looks like there are quite a few bolts on the housing?
Kris - '77 911S
Old 03-22-2006, 04:56 AM
id10t's Avatar
Upper and lower corners, only ones on the firewall in the engine compartment. Removing is usually easy, getting them back on can be tricky. You will either need a helper, or use something like a hose clamp or welded on bit of nail, etc. to keep the head from turning as you tighten.
Most of the proceedures for the 356 are the same as the VW bug. I can't live without my copy of John Muir's "Idiots guide to keeping your VW alive forever". I use Elfrinks manual or Ken Balls "Porsche 356 A B C" for specs and numbers, but Muir's book for the what and how,
Old 03-22-2006, 07:45 AM
kpfoten's Avatar
Wow--I have that Muir book! (I just bought the 356, and am a rookie, although It's gotta be easier than my '77) What a great surprise!
Kris - '77 911S
Old 03-22-2006, 11:17 AM
kpfoten's Avatar
Just took a closer look at the engine thing--it's so easy it's stupid. The backup wires popped out no problem.
Kris - '77 911S
Old 03-22-2006, 06:55 PM
Don't forget the accelerator rod, tach cable ( id10t has a '65 so it is an electric tach which has no cable!) and if your heat is hooked up you'll need to remove the cables/rods as well.
Sebastian
Sebastian Gaeta
'64 356 "C" Cabriolet
'65 356 "C" Coupe
'67 Karmann Ghia Convertible
'73 914 2.0L
'80 911SC Coupe
Old 03-24-2006, 07:02 PM
