wheelbase and track width questions
were all 356's the same wheelbase/track width and does anyone know exactly what those measurements are?
thanks paul |
Think so. Info may be in Elfrinks, but I don't have mine handy.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
356s have a whlbase of 2100mm, a frt track of 1306mm (preAs: 1290) & a rear track of 1272mm (preAs: 1250). growth in whl width accounts for variance. of course, there may be unique exceptions - it's Porsche!
thanks for the replies guys. i found the info on the carfolio site yesterday. here's the link in case anyone needs any specs.
http://www.carfolio.com/specifications/models/?man=5318&Porsche paul |
I looked over a number of their 356 model specs at Carfolio. While it may be data, it appears to be "user sourced", so I wouldn't rely on everything there as THE data. For definitive info, I recommend the factory owner's manuals or reliable sources that directly tap factory data (ie: Ludvigsen, Conradt, Elfrink & similar). The more important it is to you to get an exact spec, the more sources you need to check, & as close to "THE source" as possible.
Just what are you planning to DO to that Pre-A anyway . . . ?
keep quiet tc, you'll find out soon enough. i do have a plan though.
paul |
