Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Difference between 356 C and SC engines
Hi!
What exactlty is the difference between the C and SC engines, except for the compression ratio? What makes up the relative big difference in hp? Are there any other differences to the cars themselves?
Is it therefore quite easy these days to upgrade a C to SC spec?
Thank you kindly, I appreciate the info.
Whippet
Old 11-07-2007, 02:27 PM
Racer
preston_brown's Avatar
The cam is different too. That's about it.
-- Preston
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 11-07-2007, 03:58 PM
Wasn't the C the old S 75hp and the SC the old S-90 90hp?
63 356 So Called Outlaw
76 930
Old 11-07-2007, 07:09 PM
-- Preston
So a slightly different cam and higher compression accounts for 15 hp? Are the carbs the same? So one can then easily modify a C to be SC spec I guess.
Thanks for the feedback!
Old 11-07-2007, 09:47 PM
id10t's Avatar
Very common to rebuild a C to SC or 912 specs....
Old 11-08-2007, 04:33 AM
356racing's Avatar
Off the top of my head... Different carbs, intakes, heads, crank, and pistons but you can update everything to SC/912 specs pretty easily.
Old 11-08-2007, 08:29 AM
I think the carbs in the C are 32's and in the SC they are 40's
Dann
65' 356 SC Coupe
67' 912
04 911 Targa
67' Austin Healey 3000
Old 11-08-2007, 10:53 AM
Aha, thank you. I thought there was a little more to it. I would like to keep things as original and standard as possible. I wouldn't want to go big bore etc. - but taking a C to SC spec seems to still be within the realms of "originality".
Old 11-08-2007, 10:55 AM
I'm having 67' 912 engine done right now. Big bore kit, and Webber 44's. I think we're going to put the old 40's on e-bay. They were OK but they have to be rebuilt- throat air leakage- normal stuff for these old carbs.
As previous threads have stated, the SC is basically a 912 spec.
Good luck.
Dann
65' 356 SC Coupe
67' 912
04 911 Targa
Old 11-08-2007, 11:02 AM
C. Clark's Avatar
44's are to big for a 912, or so I've observed; other in the 912 registry have tried 44's with poor results, tuning problems, idle trouble, etc.
Chas.
356
912
911
Old 11-08-2007, 11:56 AM
That's what I thought too. I was put in touch with this guy, a mechanical engineer for Mack Trucks. He's in charge of mechanical design fabrication. He told me he's done it before. Worked on alot of 356's and 921's. He really seems to know his stuff, so we're giving it a shot. He's using the same cam but fabricated manifolds and other modifications. I'll let you know how it works out.
He's going to put this engine in my C, while he rebuilds the C engine.
Dann
65' 356 SC Coupe
67' 912
04 911 Targa
Old 11-08-2007, 12:07 PM
Dana, Chas. is right. Also make sure the 40's are mated with the correct manifolds as sometimes the 44 manifolds are used by mistake with the 40's. The linkage to the throttle arms my need some work too to get full throttle. I made these errors with a 912 so I speak from bad experience. Jim
Old 11-09-2007, 05:01 AM
Racer
Just to clarify the carbs:
Original C's came with Zenith 32 NDIX's, and the SC's came with Solex 40PII-4's. And yes, the intake manifolds are of course different.
Webers or Dellortos are a common upgrade for either engine. Dellortos on a C cam can give a nice bit of extra grunt.
Preston Brown
Old 11-09-2007, 06:59 AM
