Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
912 engine in 356?
Hello
What mods are needed to put a 1965 912 engine in a 1958 356?
Axel
Old 06-02-2011, 12:57 AM
id10t's Avatar
Think the older 356s had a 180mm clutch - the C/SC/912 use a 200mm one. Also the 912 is 12 volt generator, the '58 356 is 6v so possibly new bulbs all around and changes to your gauges.
Old 06-02-2011, 07:00 AM
Hello
Thanks for reply.
Do you know if the larger diameter clutch/flywheel will fit inside the gearbox without mods?
Axel
Old 06-02-2011, 07:18 AM
It won't fit and the starter motor and flywheel teeth won't mesh. Suggest you get a 356 flywheel/pplate/TO bearing/clutch and put it on the 912 engine. Also, it's quite a bit easier to put the 356 generator stand and generator on the 912 rather than trying to convert the car to 12 volts.
Chuck
Old 06-02-2011, 08:48 AM
