leftover part ID
Can someone please tell me where these two Grommets should have been installed on a 356b engine. didn't see any obvious use. each one is around .625 inches OD, .310" ID, .335 thick. Thanks for all help!
![]() edit: maybe the grommets from the oil cooler? if so, was replaced, with new grommets. Last edited by lotuseleven; 06-08-2014 at 08:48 PM.. |
I believe one goes to the tin above the flywheel for the fuel line to pass through.
One more vote for grommets to protect fuel line, clutch cable, etc.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
