Wideband 4.9 lambda afr setting
Have just installed a plx wideband bluetooth.
Very easy to install and works great, you can custom setup the colors on your phone😀
My question is, can you adjust the AFR, i have a idea that the lamba is trying to set the AFR at 14,7 all time except when you have WOT? When idle and crusing 1500-3000 rpm i read 14,4-14,9 AFR all the time only when WOT it drops to 12-13AFR?
Old 06-25-2018, 11:47 AM
You are correct in that when the system is operating in closed loop, it is trying to achieve 14.7.
Old 06-25-2018, 11:50 AM
14.7 is optimum mixture.
You do want WOT and high power production to be bit richer just to be safe.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-25-2018, 04:23 PM
Dicklague.
But how du i adjust WOT, or is it even possible?
Old 06-26-2018, 06:50 AM
what year and model are you working on? yes there are methods of adjusting WOT mixture but it varies depending on what type of system you are running.
Old 06-26-2018, 07:05 AM
1980 sc lamba original system.
Old 06-26-2018, 08:44 AM
1980 has the simplest (dumbest) lambda system, there is no modifying it. It doesn't have the idle and WOT switches that the 81-83 has.
Best option is to disconnect the O2 sensor from the harness which defaults it to an open loop.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-26-2018, 08:54 AM
