Hooking up a MSD to an SC
So I have a '83 SC engine, PMOs, I just installed the MSD-6AL box on it, a high vibration coil, magnecore wires, bosch plugs. I just had a quick question if someone knew, do I hook up the green wire to the white MSd sender wire? It has two leads on it, do they both go into one? I'm not sure if the wire in this distributor is correct or not.
What is the benifit of using a '78-'79 SC distributor?
Thanks for the help.
VintageExcellence.com
Old 02-28-2003, 07:06 PM
CamB's Avatar
I'm pretty sure the MSD connects the two outputs on the other end (the purple and some other colour) to the two wires coming out of the dizzy.
Wait 'till someone can tell you the right answer.
The white wire is for if you have points or a Pertronix.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 02-28-2003, 07:34 PM
Super Moderator
cstreit's Avatar
The green wire has two wires. You hok it up to the external sensor wires on the MSD. I think they're like purple and green or something. (THe magnetic pickup wires...
Do a search on MSD wiring and you'll get what you need.
Actually here it is...
MSD wiring advice (connectors)
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-28-2003, 09:37 PM
Thanks you much! I will use the magnetic trigger wires then. It should fire up in a few hours later today.
Old 03-01-2003, 12:26 PM
