cycling has-been
bkreigsr's Avatar
How to un-epoxy short shifter.
Hoping that maybe someone will recognize the bonding agent used to attach my lever to the Tarett short shifter.
Heat?, Propane, Map?
Also thought about Dremel cutting a relief slot into the housing, then heat, twist.
I need to separate the two pieces and re-clock to get the two tangs to align correctly.
Thanks, Bill K
Old 07-03-2018, 08:56 AM
Most epoxy will break down with heat. I would think propane would be sufficient.
Old 07-03-2018, 08:59 AM
I would rather be driving
jpnovak's Avatar
Heat. a good heat gun might also work. Scrape off the residue while its soft.
Old 07-03-2018, 09:32 AM
a propane torch should do it.
I would weld it back in place with a MIG welder. I had my shifter joint break on the road and it was not pretty.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-03-2018, 08:29 PM
