cycling has-been
How to un-epoxy short shifter.
Hoping that maybe someone will recognize the bonding agent used to attach my lever to the Tarett short shifter.
Heat?, Propane, Map? Also thought about Dremel cutting a relief slot into the housing, then heat, twist. I need to separate the two pieces and re-clock to get the two tangs to align correctly. Thanks, Bill K ![]()
73 911T MFI, 76 912E, 77 Turbo Carrera |
Most epoxy will break down with heat. I would think propane would be sufficient.
I would rather be driving
Heat. a good heat gun might also work. Scrape off the residue while its soft.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
a propane torch should do it.
I would weld it back in place with a MIG welder. I had my shifter joint break on the road and it was not pretty.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Thread Tools | |
Rate This Thread | |
