Brew Master
cabmandone's Avatar
I'd think that worst case you'll have to drop the HE and have a shop tack weld it back in place if that's what ends up being the problem.
Old 07-16-2018, 02:56 PM
Ok - so that was not the problem! The exhaust putty worked a treat and the exchanger is rock solid. will have to check for exhaust leaks from the whole system before taking things apart. Wondered if the cat had packed up?
Old 07-18-2018, 08:36 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Outstanding.
If cat clogged, you will feel it in poor acceleration or glowing red hot temps on the cat.
'85 Carrera Targa
PCA/POC
Old 07-18-2018, 09:20 AM
Brew Master
cabmandone's Avatar
Look around for any carbon buildup on the exhaust joints and at the manifold gaskets. Like Draco said, if the cat was gummed up, you'd notice performance issues as well as a glowing hot cat. Good luck and keep us posted!
Old 07-18-2018, 09:40 AM
Will do - thanks for your support and advice......
Old 07-18-2018, 09:56 AM
Ok - so not an exhaust issue so have created a video of the sound when engine running. As you can hear, when increasing revs steadily no noise, give the accelerator peddle a pump and you can hear a noise - any ideas? Do you think it is a valve issue, ignition issue or (dreading this) a bearing issue?
https://youtu.be/QlETDee7s8c
Old 08-04-2018, 09:52 AM
Brew Master
cabmandone's Avatar
Link to video doesn't appear to be working.
Old 08-04-2018, 10:06 AM
DRACO A5OG's Avatar
+1 Link broken, make sure it is in public to view
'85 Carrera Targa
PCA/POC
Old 08-04-2018, 11:06 AM
Sorry folks - link should now be working....ticked the wrong box!
Old 08-04-2018, 02:07 PM
Still here
pmax's Avatar
Remove the lower valve covers and have a look at the head studs.
Old 08-04-2018, 02:30 PM
DRACO A5OG's Avatar
Uh oh,
Sounds like a head to case leak, maybe cam tower.
+1, remove covers and inspect studs or if you can do a leak down test. That will certain show a leak and pin point were it may be coming from.
Sorry to see your troubles Brother :-(
'85 Carrera Targa
PCA/POC
Old 08-04-2018, 02:50 PM
Thanks for the suggestions. Friend of mine suggested chain tensioner may have collapsed. What do you think?
Looks like a lot to investigate!
Old 08-05-2018, 01:04 AM
DRACO A5OG's Avatar
That is possible since you have the SC, if you do not know the complete history, you will not know if PO put a tensioner guard or updated them to a carrera oil fed ( you would see oil line going into the chain covers )
You can remove the covers and inspect the tensioners to make sure.
'85 Carrera Targa
PCA/POC
Old 08-05-2018, 06:48 AM
Hi everyone - just thought I would update on the issue. After a leak test two cylinders were well down so engine had to come out - no loose bits and pieces anywhere, studs all good etc. Problem has been identified as blown head gaskets - the springs inside two had gone bad and two others were in the process of failing. So - new gaskets purchased and ready to go in - just a question - is there a 'right way' for the gasket to go? One side appears flat and the other side slightly curved.
Old 09-29-2018, 12:07 AM
Brew Master
cabmandone's Avatar
I don't recall. You might consider sending a PM to Bruce (flat6pac) or John Walker both would probably know for certain.
Nick
Old 09-29-2018, 02:44 AM
Thanks Cabmando - can't find flatpac6/John Walker PM as the area had been disabled by administrator! Can you provide a link for me?
Old 09-29-2018, 03:16 AM
DRACO A5OG's Avatar
Post a pic of your old gasket and new one.
'85 Carrera Targa
PCA/POC
Old 09-29-2018, 07:59 AM
Here is a picture of the one that blew -
Old 09-29-2018, 10:35 AM
Ooops - last post is a new one, this is one that blew
Old 09-29-2018, 10:38 AM
On a new one there is a 'flat' side which does not show up very well.
Old 09-29-2018, 10:40 AM
