Speedometer wire disconnection
How to disconnect this black cable? I don't want to yank on it and destroy something.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 07-14-2018 at 09:32 AM.. |
Looks like the ODO reset cable. Might be easier to disconnect on dash (other end).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Is it a pull or twist on the other end?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Most folks disconnect at the dash but you can remove at the gauge as well.
To pull from the gauge. Best to put knife or thin screwdriver under it and gently around it to work it up. This is what it looks like removed. WTB: 911 odometer reset cable Don't just pull by the cable or you will screw it up (hard to come by). Also, don't use pliers on plastic and break it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 07-14-2018 at 11:39 AM.. |
