PeterTarga's Avatar
Rear Targa Bar Seal - installation question
Hello,
Should this seal 90156593041 (Rear Targa Bar Seal, rear glass window)
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=90156593041
be glued ? And if yes which glue must be used ?
Peter
Old 07-13-2018, 08:58 AM
old man neri's Avatar
I didn't on mine. That's not to say I was correct.
Old 07-13-2018, 10:45 AM
No glue on mine either. Fit was quit snug.
1982 911 Targa, 3.0L ROW with Webers
Old 07-13-2018, 10:46 AM
PeterTarga's Avatar
Ok, I think also without glue. Will do it like that.
Old 07-13-2018, 01:28 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
Just finished this job (almost). Will use non-hardening glazing compound between seal and window and between seal and metal after the window settles for a few thousand miles. Wisdom here:
To "Glue" or-not-to "Glue!
and here:
Why windshield trim should be a regular maintenance item.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-13-2018, 01:42 PM
and here:
Except the seal he is talking about is not really the main water tight seal. It's almost a decorative seal / dust seal.
Old 07-13-2018, 02:08 PM
Coram Deo
RDM's Avatar
You're right- sorry about that. I didn't follow the parts link.
Push on and forget (the seal, that is).
Dru
Old 07-14-2018, 02:04 AM
