nene's Avatar
To "Glue" or-not-to "Glue!
I am in the process of replacing my front windshield seal and wanted to get opinions on whether to "glue" it or not? I have read several posts notating to "Glue" in the windshield to avoid rust issues down the road.
Thanx,
Serge
Old 05-13-2014, 09:30 AM
kodioneill's Avatar
No glue, new gasket.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-13-2014, 09:36 AM
Depends on the model year; the 964 (and later?) units were glued at the factory.
'90C4
Old 05-13-2014, 09:43 AM
wayner's Avatar
Yes glue, my new gaskets leak
...There, its a tie
I received the following recommendation and I just used this on another model car as a test.
Going to redo my new seals on my 1973 911, and yes, I did use the recommended seals but still got tiny visible leaks under the right conditions.
I got this recommendation from somone here. This is what I will use when I redo them one more time.
3m Auto Bedding and glazing compound.
(I guess technically it is not a glue, and can be more easily removed and cleaned up later)
P.s. I am also the one who started the thread on why seals should be a regular maintenance item.
I don't know anyone who has removed and installed glass as many times on the same single car or exposed it to as many elements as I have for research purposes (versus for paying customer purposes). Each time I have removed it and replaced it with yet another new seal I find evidence of moisture even in areas where I had not detected the initial leak.
SOLD - 914 wide body hot rod
Old 05-13-2014, 09:46 AM
nene's Avatar
I really think gluing it would be double-assurance of it not leaking.
This is for an 86 Carrera.
Old 05-13-2014, 09:49 AM
TheSt|G's Avatar
...There, its a tie
Going to redo my new seals on my 1973 911, and yes, I did use the recommended seals but still got tiny leaks.
Here is what I will use when I redo them.
(I guess technically it is not a glue, and can be removed and cleaned up later)
I don't knwo anyone who has removed and installed glass as many times on the same single car or exposed it to as many elements as I have for research purposes. Each time I have removed it and replaced it with yet another new seal I find evidence of moisture in areas where I had not detected the initial leak.
Got the thread link?
I'm of the same mindset(already replaced a ton just because it is a 30 year old car) and I would love to see your thoughts on it.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 05-13-2014, 09:58 AM
nene's Avatar
Wayner, I did have an opportunity to have read your lengthy thread, and that is why I bring the question up. Thanx for the research.
Serge
Old 05-13-2014, 10:41 AM
wayner's Avatar
My other thread mainly documents the carnage.
This current thread that we are on is a good place to ask and debate the issue. Thanks for starting it Serge
I think this applies to all 911/912 cars up to but not including 964s
Old 05-13-2014, 10:43 AM
wayner's Avatar
Here is the other thread
Why windshield trim should be a regular maintenance item.
Old 05-13-2014, 10:46 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Huh,
Installed mine without glue, works in downpour that overpowered the windshield wipers on high. The seal was the Pelican aftermarket one as well, proper install was/is the key. Glue will not solve for improper installation.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-13-2014, 10:48 AM
Go-Kart Mozart
JAR0023's Avatar
Don't do it. If installed correctly with the OEM gasket(avoid the a/m gaskets), the windshield will not leak. I replaced mine last year. The old gasket had been "glued" more than once. I spent 3-4 evenings in the garage cleaning all that crap up. New glass, new OEM gasket, old trim. Half hour to install and zero leaks in 12 months and 10k miles. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 05-13-2014, 10:52 AM
Brew Master
cabmandone's Avatar
I installed my new seal without glue. I used a method recommended by another Pelican of tapping the aluminum trim ring at the corners to move the seal over into place. I haven't driven it in the rain nor do I plan to so I can't tell you if it leaks or not. I personally don't see a need for sealant if the new seal is installed properly.
Old 05-13-2014, 10:55 AM
wayner's Avatar
I'm curious then why the factory installed seals eventually leak?
Old 05-13-2014, 10:56 AM
nene's Avatar
JAR, of course I am concerned with the leaking effect, but trying to be proactive and avoiding the water creeping in between the seal and the car and begin the "rotting" effect.
Old 05-13-2014, 10:59 AM
AGE, the seal is not a lifetime part. Rubber ages, and then shrinks, causing leaks.
Old 05-13-2014, 11:03 AM
wayner's Avatar
Just for reference, I am not a big fan of urethane to glue these but I really do like how the 3m glazing compound that I mentioned above works with these seals
Old 05-13-2014, 11:04 AM
Brew Master
cabmandone's Avatar
I'm going with "shrinkage" and the fact that some owners don't pay attention to how the seal mates to the window frame and allow gaps to open up without addressing them.
Old 05-13-2014, 11:11 AM
kodioneill's Avatar
I've installed 20 or more no glue no leak. If you glue it have fun trying to remove it.
1982 chiffon 911sc
Old 05-13-2014, 11:42 AM
Ken911's Avatar
Well if you have ever had the unpleasant experience or the windshield blowing out at at around 150mph then you'll glue it. My 85 had the window try to blow out during a high speed run. seems the cabin was pressurized by the air coming in the front vent. I could see daylight around the bottom passenger corner. Pulled it out got a new gasket and glued it in.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-13-2014, 11:48 AM
Under the radar
Trackrash's Avatar
According to my manual (Haynes) "From Dec. '69 USA models have a glued-in windshield.... Your Porsche dealer will be able to supply the glue...."
I didn't glue mine in when I replaced my seal in '85 and haven't had any problems, but I avoid rain.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-13-2014, 01:17 PM
