Flojo's Avatar
Dynamat or what?
I’m in progress of scraping the whole floorpan.
Swapping the bitumen for... Dynamat(?).
Which should I buy?
As I can only order online I cannot examine it beforehand and I want something thin, light.
What Dynamat (or similar) is thin and light?
RS carpet is next.
Any suggestions?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 07-15-2018, 12:22 PM
TheSt|G's Avatar
Normal Dynamat is not particularly light, but they do have a new version that is 30% thinner/lighter. It works wells as a resonance changer for panels, but it is only mildly a sound deadener.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 07-15-2018, 12:37 PM
Cajundaddy's Avatar
Depends on your goals. For a lightweight street solution just a very thin layer of carpeting. The tradeoff is more road noise. Dynamat helps reduce exterior road noise but is not light. Figure out how many yards you will need and go to their site for weight specs to see what it will weigh.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 07-15-2018, 01:16 PM
I use this stuff on my cars, much cheaper than dynamat
https://www.amazon.com/gp/product/B0751CBXBT/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Old 07-15-2018, 01:45 PM
Ctopher's Avatar
You might also consider looking into aircraft based sound proofing material. While I don’t have any experience I have read and heard about their materials as they are also highly focused on weight savings while gaining sound proofing. Just another option to consider.
Old 07-15-2018, 01:50 PM
Cajundaddy's Avatar
^^ This!
Old 07-15-2018, 01:57 PM
I used b-quiet on multiple vehicles.
1974 911 coupe 4 speed
Old 07-15-2018, 02:31 PM
Originally Posted by jferrante View Post
I bought some similar to this. I haven't started putting it in yet. Over it will go a layer of closed cell foam bonded to a layer of vinyl (MLV). I bought 19 linear feet from Super Sound Proofing. I'll be putting my carpet over that. The 19 ft. of CCF w/ MLV weights in at 80 lbs. Haven't weighed the butyl sheets yet.
Marv Evans
'69 911E
Old 07-15-2018, 06:52 PM
H-viken's Avatar
To remove resonance you only need well placed strips, not whole sheets. That alone will save some weight. Only sound deadening needs to be fully covering
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 07-15-2018, 08:22 PM
