P201 Engine Yoke clearance with crossover pipe
Hi everyone,
Car is 1989 911 3.2 liter. Have my engine on my temporary ATV lift waiting to mount a SIR tools P201 engine yoke. Have others experienced interference with the crossover pipe in the pipe itself (not the mounting flanges)? My specific question is, what did you do to remove crossover pipe? all hardware is severely rusted, so nuts are losing their hexagons pretty easily. I'm ready to dive in with dremel and cutting tool but I can't access one of the nuts on the lower inboard passenger side. lower inside nut on driver side has slightly better access. Have people mounted the yoke on CAT side, flipped engine upside down for access, removed exhaust, then relocate yoke? Anyone been here, leave the two difficult to access nuts, swing crossover pipe down a bit, mount yoke. Looking for a Been There, Done That. thanks, mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
Registered Minimalist
I removed mine prior to mounting on the p201.
Try all the usual suspects? Heat, kroil, skinny wrenches. You can grind down a cheap harbor freight wrench or ebay wrench. I think HF even has a skinny set in metric. Once you get the pipe nut loose, you can use a big socket on the fitting if I remember correctly.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Probably need to cut a notch in it. Had to do it with mine.
Member 911 Anonymous
+1
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Spiderman
I remember a minor amount of grinding on my P201 to attach. Less than 1/4" or so in some area maybe ?? Then all was good for the entire process. Others reference it in various P201 threads.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Still here
Just to finish out the thread for others in similar situation. My question wasn't do I need to remove my crossover pipe, but how did people remove an extremely rusty bolt / nut on the lower rear passenger side flange. My challenge was my original selection of ATV lift, sheet of plywood, and 2x4's with heat exchangers on the 2x4's. I knew I was going to have to grind, just couldn't figure out how to get in there. A little embarrasing that I didn't think of this earlier, but all I did was take short 6" 2x4 and lift the engine up a little higher. It was enough that I could get the dremel in to slice up the nut a bit, and hammer/cold chisel to get the nut started moving. Anticlamactic solution.
Also, just in case anyone is thinking of this, the sears "low profile damaged nut removal tool" didn't bite and work in this situation. Thanks for everyone's thoughts and comments...
I was in this situation just on the weekend, which is how I just came across this thread.
For the rusted nuts/bolts that I could access, I held a spanner on one side and a impact wrench on the other. They easily zipped off. The two inner nuts/bolts were difficult because almost nothing I used would grab them. In the end I grabbed one end with a pair of vice grips and the other side with a spanner. Then I hit the spanner with a persuader. (manual impact wrench!) got it loose. I was also doing this in order to fit up the yoke, but wasn't able to remove the cross over pipe, even with the nuts removed. I assumed that the pipe might have gone slightly inside the heat exchangers? Or should it just slide off? I ran out of time/daylight to really get stuck into it to see why it was sticking. Looking at diagrams, there shouldn't be anything holding it on there. |
My yoke from Porsche factory has already the cut out on it..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Use the right yoke........
I have no problem installing my 911 engine yoke at left or right side of the engine for the removal and installation of the cross over oil line. ![]() ![]() ![]() ![]() For removing frozen nut, use heat and impact tool Tony |
I wouldn't have a problem fitting the yoke either if my cross over pipe was the same as yours.
However, I believe that I have the 930 configuration which appears to be much fatter than your cross over pipe. ![]() Heat wasn't required to undo the bolts. Just the impact wrench and some WD-40... although I doubt the WD-40 had time to penetrate much, esp since the bolts were horizontal. |
Still here
The other is for oil.
The crossover pipe in question is for the exhaust. |
I can't see how anybody, including those with the yoke with a section cut out of their yoke could fit it to the engine without removing the exhaust cross over pipe. |
adrock..that is exactly the reason for the cut out section so it fits ,trust me;-)
Ivan
Correct engine yokes.......
Adrock, I have three (3) 911 engine yokes and have loaned them several times to PP members. Both SC and Carrera 3.2 engines with comple OEM exhausts mount perfectly with these yokes. I have done more than a dozen engine rebuilds and can not understand your problem if you have the correct yoke. Some cheaper versions have problem with fitment. Not the ones we got from Pelican Parts. Listen to Ivan. He has a lot of experience in mounting 911 engines on engine stands. Tony |
Sent from my Pixel 2 using Tapatalk |
Here's my flywheel end with cross over in place....
![]() Sent from my Pixel 2 using Tapatalk |
well? to install the yoke you have to remove the clutch first...
Ivan
Still here
well it is easier, no reason to leave the clutch on it;-)if you are lifting the engine with yoke it is is for a reason ,let`s say working on it...big PIA to take it later or?
also it is Tony`s engine without the cross over pipe;-) Ivan
