Random Horn Beeps
I have a 1969 911T. Recently, the horn has begun sounding when I turn the wheel to the left after having turned it to the right, mostly after harder turns. I have already replaced the contact button pin, with no benefit. Thanks in advance for your thoughts. Rich
The wire coming up through the column is shorting to ground. Carefully check the insulation
I had a little problem with that years back due to loose screw on steering wheel.
Ed 1973.5 T |
Bingo. Thanks!
