Oil temp sensor compatibility- numerical gauge
1982 SC. My oil temp gauge is the numerical style and I want to replace the temperature sensing unit in the engine. I am getting conflicting part numbers from Pelican’s catalogue and Porsche PET. I am trying to plan ahead and make an order of parts. Unfortunately, I don’t have access to the car for a while and can’t pull the gauge for more info.
What’s the best way to determine which sender is compatible?
Thank you,
Sent from my iPhone using Tapatalk Pro
1987 Marine Blue 930
1982 911SC
White Plains, NY
Old 07-22-2018, 10:18 AM
The 82will have a chrome sensor with a 911 part number.
The early sensor is brass and has a 901 part number
The numerics on the dash can be either as there was a time selling both units to install in dash with sender.
Bruce
Old 07-22-2018, 11:55 AM
Bruce
Thanks for responding Bruce. Did the ‘82 come stock with a numeric temp gauge? I thought they had the hash mark style temp garage and therefore a different sensor. I guess I’m trying to confirm which sensor is best for a numeric gauge.
Old 07-22-2018, 12:10 PM
Going through the pet it looks like the date stamps is most important
I recall a 77 had numerics and used the later sender.
Bruce
Old 07-22-2018, 12:50 PM
There was a posting recently about the temperature topping out different depending on the year of application
Old 07-22-2018, 12:53 PM
Oil temp
I know the one on the left was out of a 69 but they’re both early to go with the brass 901 part.
Bruce
Old 07-22-2018, 01:43 PM
Bruce-
Here’s the gauge I’m trying match the sensor to. I’d pull it an look at the markings, but I won’t be with the car for a few weeks.
Thanks for any insight.
1982 911SC
White Plains, NY
Old 07-22-2018, 05:34 PM
We know the brass one is good for 340 so it will have to be the chrome one that should already be on an 87 930.
Bruce
Old 07-22-2018, 08:01 PM
Mark Salvetti's Avatar
You want sender 901.641.632.00. That temp gauge was used from 1974-1977. I'm pretty sure none of the SCs came stock with numbers.
As a double-check, I have the same temp gauge in my 1979. In my case, I bought it aftermarket, and it also came with a 901.641.632.00 sender. It is brass.
Mark
1979 911SC Targa
Old 07-22-2018, 08:25 PM
Bruce/Mark- thanks for the responses and information. I’ll report back once the job is done.
Will
Old 07-23-2018, 04:17 AM
theiceman's Avatar
Mark
Hi Mark , I bought mine aftermarket too, I ran into the same conflicting information as OP . I must have guessed wrong
I often wondered if I had the right sender in it.
mine is chrome .. dammit another project...
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-23-2018, 05:26 AM
