Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Need a lead for front hub work
The outer races in my front hubs are no longer a press fit, as a matter fact, they are a loose fit. In doing my search, others have mentioned the bearing surface can be machined and a sleeve fitted. Can anyone suggest a reputable shop or person who has experience with this job and as always, is reasonable. Thanks
1986 Targa Guards Red
2021 MT09 SP
Old 07-22-2018, 11:45 AM
Good used hubs should be easy to find.
206 637 4071
Old 07-22-2018, 01:17 PM
kevingross's Avatar
It might be possible to machine them, either sleeve or install outer races with a larger OD. However, I would be leery of reducing material in the hub by any amount, especially if you take your car on the track. As John suggests, good used hubs are likely a better option, and I would strongly encourage you to have them checked by a company that does materials testing before you install.
I had exactly this situation happen to me a couple months ago. 944 Ecology was able to supply me with a good used hub for my own 944S that I used until Racers Edge had a new run of their billet hubs available. Expensive but cheaper than the consequences of a failure! Apologies, I don't know who makes such a thing for 911 series cars. Good luck, stay safe,
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 07-22-2018, 02:48 PM
Thanks for the good advice guys.
2021 MT09 SP
Old 07-22-2018, 03:23 PM
