Rebuilt Chain Tensioner Life Cycle?
I have a 1983 SC with 227k on the ODO and still running the original 3.0L. I purchased the car several years ago with ~195k on it and at that time I rebuilt the chain tensioners (new seals, o-rings, springs etc) and installed some fail-safe collars for peace of mind.
Recently the car started making a rattling chain noise when cold which I am attributing to failing chain tensioners. I have not removed the rear covers yet to verify this. Rebuilding the tensioners is a lot more cost effective than purchasing new ones but I would have expected a longer life cycle than 30k miles. Although I replaced all of the wear components I am wondering if the metal parts are worn out of tolerance leading to this failure.
Is this typical of rebuilt tensioners? Are there any other options for servicing them to as-new condition or is it better to replace them?
Old 07-23-2018, 10:00 AM
Under the radar
Trackrash's Avatar
I rebuilt the tensioners in my '71 in '85. One started to fail in around 2000 after about 75K miles.
I was told by an experienced trained Porsche mechanic that there was a Porsche service bulletin that recommended a tensioner rebuild at 40K miles.
When a tensioner is rebuilt it is important that the upper chamber is filled completely with oil, as that is the only oil the tensioner will have during it's life.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-23-2018, 11:04 AM
