'73 911 T Targa
Multi ground spark plugs
I saw an earlier post which showed a multi-ground spark plug (sometimes called multi-electrode)
I'm wondering if these have any benefit in older CDI cars? |
'73 911 T Targa
Like this one. Three sparks has got to be better than one, right?
I seem to remember something about those plus and using them in a 944. It wasn't good. But I don"t remember the details though.
Ever try to gap one of those?
Typically a marketing ploy to buy their not inexpensive plugs. How much? $6-$12 ea?
In actual practice, spark jumps to the electrode with the least resistance, and that’s usually just one. However there are two or more other backup electrodes you paid for in case you need them. Those in the know also warn that the extra metal sitting there creates a shroud that could disturb the flame front. And yes, there’s an issue of setting the gap. Unless you have a late model engine, a regular, recommended single electrode NGK or Bosch is all you need. Sherwood |
Absolute garbage. I bought one set, many years ago, to run "better" in my "dirty" MFI motor. I didn't get a couple hundred miles on them before they fouled out. I parked the car and walked several miles to an auto parts store to buy simple, cheap, single electrode NGKs and drove merrily ever after.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Still here
What's the technical lowdown on this ? I tend to believe one sufficiently strong spark is enough. |
Multispark (eg firing a spark more than once) is putting more spark energy into the cylinder. Has to be fast enough though to make more power.
www.classicretrofit.com |
That picture is somewhat of a hoax. Long camera exposure time to make it appear as if all gaps are firing at the same time. Reality is that only one gap will fire for each spark event, so other than allowing the ground electrodes to last longer there is really no advantage. Fred
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Ngk.
Used them for decades. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
