WP0ZZZ's Avatar
Question Strut: Bilstein or Boge?
I'm planning a full suspension revamp in my euro MY80 SC. First I would like to identify what front struts are mounted in the car. Can you identify the type from the pictures?
I believe that the Bilsteins should have a pin which I have been unable to see.
Old 03-06-2018, 03:22 PM
Under the radar
Trackrash's Avatar
Yea, they do look like Boges. No way to know for sure till you take the dust cover off. There is a manufactures stamp on them you might be able to see with a mirror.
Either way, even if they are Boges they could have Bilstein inserts. What rear shocks do you have? That could be a clue.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-06-2018, 06:20 PM
Mine looked just like yours before I rebuilt the whole front end. Lot of work. Well worth it. Good luck. Here's a picture of mine. Just finished last week.
Old 03-06-2018, 06:27 PM
faverymi's Avatar
Go with Bilstein. You'll be happier
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
WP0ZZZ's Avatar
Good idea about looking at the rears although the may have been changed in the last 38 years so I would still be in doubt about the brand of the front struts...
So, to know for sure, do I need to take the strut off to remove the dust cover to be able to see the brand?
Is this a Bilstein strut?
I'll go for Bilstein shocks but I need to know what kind of strut I have before ordering!
Old 03-07-2018, 03:45 AM
Uncertifiable!!!
Uwon's Avatar
Why? Are you referring to adjustable or non-adjustable? Just trying to understand reasoning.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-07-2018, 04:04 AM
I hear the Bilsteins are great in that if you ever want to go with stiffer torsion bars they are already sort of set up for a stiffer set up.
No physical quantity completely explains its own existence
Old 03-07-2018, 05:53 AM
gearhead
Your struts look schizophrenic. RSR racing Bilsteins use a yellow housing. Standard Bilsteins use a green housing (like your top). Boges are black.
What you need to do it jack up the car and remove the wheels. And start cleaning them up prior to removal. If they are Boges, they will clearly have a 911 part number on them and a date. You can buy Bilstein inserts for them, so what housing you have in the first place doesn't matter a whole much. My only concern is it kind of looks like you have one Bilstein in yellow and one Boge in black.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-07-2018, 06:34 AM
I don't see any roll-pin holes (bilstein) in any of the pics.
206 637 4071
Old 03-07-2018, 06:55 AM
3rd_gear_Ted's Avatar
3rd option - JRZ strut inserts ???
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-07-2018, 09:32 AM
WP0ZZZ's Avatar
Where would the strut part number be?
Is the part number in the same place for Bilstein and Boge struts?
Old 03-07-2018, 05:20 PM
WP0ZZZ's Avatar
So, after removing the wheels I could clearly read the marking showing that the struts were made by Boge. Are Boge struts inferior for a hotrod/track application compared to OEM Bilstein struts?
Old 08-02-2018, 10:25 AM
Under the radar
Trackrash's Avatar
Many hot rodders or track guys prefer the Boges. They can take inserts made by either Bilstein, Koni, or Boge/Shach.
Gordon
Old 08-02-2018, 10:34 AM
I have put Bilstein inserts into boge struts, mine came with the green cover also. Probably has the Bilstein inserts already in there because of the cover. Best way to check is to take them out
Old 08-02-2018, 10:55 AM
WP0ZZZ's Avatar
Why do they prefer them?
Old 08-02-2018, 11:24 AM
Cory M's Avatar
The Bilsteins are preferred by people who are raising the spindles to optimize the suspension geometry on lowered cars. The reason for this is that the Bilstein housing uses a constant cylindrical shape, while the Boge strut tube increases in diameter above the spindle which makes it impossible to raise. If you aren't raising the spindles I don't think it matters because you can get Bilstein strut inserts for either one.
Old 08-02-2018, 12:30 PM
Tags
bilstein , boge , struts
