Getting wheel vibration at different speeds
So my steering wheel vibrates at different speeds, starting around 55mph. Then it goes away up until 75ish. Then it goes away a bit after that too. Maybe wheel imbalance?
Anything else I should check?
Old 07-26-2018, 09:42 AM
Administrator
Dmitry at Pelican Parts's Avatar
I would check the driveshaft as well. Other members will chime in with their expertise.
Old 07-26-2018, 10:13 AM
Brew Master
cabmandone's Avatar
Depending on the type of weights used to balance the tires, you could have lost a weight. I'd take it in and have the tires balanced.
Old 07-26-2018, 10:20 AM
Ctopher's Avatar
You say steering wheel....is it just the steering wheel shaking or the can you feel your butt vibrate? Asking to determine front or back and as others had mentioned....balance the wheels being something to consider.
But if its the steering wheel only then up front you have tire balance but it could also be tie rods. Jack the front of the car up and with the steering wheel locked move the wheel left to right and inward and outward to determine if you have any play/movement and if you hear any clicking from the ball joint.
If its rear, the drive shafts are another items to consider beyond balancing.
The big question is has the car sat in a single place for a long time? You could have developed flat spots on the tires. Check pressure and drive a bit but if you are driving at highway speeds and your tires are old with flat spots or more than 4yrs from manufacturer date on the tire its time for new tires. Old tires are dangerous, you could have flat spots, dry rot or a separation of the tread which could come off at highway speeds.
Ctopher
Old 07-26-2018, 12:32 PM
Cory M's Avatar
Always start with the tires, that's usually the problem. Could be a simple unbalanced/damaged tire or a bent wheel. I've also had similar vibrations cause by loose CV joints (on the hub side) and loose/missing motor mount bolts.
Old 07-26-2018, 12:54 PM
Does it drive like a dump truck?
Sorry; I couldn't resist.
Derrick
Old 07-26-2018, 01:15 PM
wayner's Avatar
Any corrosion?
Check the front forward torsion bar sheet metal mounts too if everything else checks out ok
SOLD - 914 wide body hot rod
Old 07-26-2018, 01:21 PM
rnln's Avatar
I would do in order from cheapest:
wheel/tire balance
check wheel bearing
check for wheel round/true
replace tires.
Fat butt 911, 1987
Old 07-26-2018, 01:52 PM
irl irl is online now
irl's Avatar
Send a message via AIM to irl
Driveshaft???
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 07-26-2018, 02:12 PM
kevinbodman930's Avatar
Check the lug Nuts
Old 07-26-2018, 02:32 PM
Originally Posted by kevinbodman930 View Post
Check the lug Nuts
What should the nuts be torqued to?
I’ll check those and then the tire/wheel balance next. The vibration is definitely only in the wheel. Tires are brand new.
Thanks all for suggestions!
Old 07-26-2018, 03:25 PM
Still here
pmax's Avatar
Do this check first.
Road Force Balancing | MotorWeek
But everybody says alright, we’ll balance the tires. That’s part of the equation but balancing isn’t always the answer. So you have to go a step further. What we have here is a Hunter Road Force balancer. This takes it to a new level.
This roller back here comes out against the tread of the spinning tire. It applies 1,200 pounds of pressure to simulate the weight of the vehicle on the tire as it rolls down the road. Now a computer in the machine, and sensors, sense variations in the tread. Stiffness, or the tire isn’t completely round, or anything that would prevent the tire from rolling smoothly when its weighted by the car.
Then it translates that into a road force reading. We have a warning that it is excessive. Next thing we do is take some measurements.
What we did is we took measurements of the rim. Of course the machine had already measured the tire. Now we can do what is called match mounting. We’re going to take the high spot of the tire and match it against the low spot of the wheel. It’s really more complicated than that, but to make it understandable… that’s what we’re doing. And it’s telling us here that we have 15 pounds of road force in the tire and if we swapped the tire around, moved it around on the rim, such as it’s showing us over here, that we can reduce this to 8 pounds total.
That brings us in spec and that means now we’re going to have a smooth riding tire.
Old 07-26-2018, 05:38 PM
Torque is 96 foot pounds / 130 nm
Old 07-26-2018, 07:00 PM
Functionista
manbridge 74's Avatar
Originally Posted by irl View Post
Driveshaft???
I bet he meant driveshafts which is what Porsche calls axles....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-26-2018, 07:16 PM
T77911S's Avatar
year?
start with: old tires, flat spots, (mine had lots of them ) balance then bent rim.
a bad bushing in the steering column makes it worse.
then I would look at tie rod ends.
if you get it aligned (after new tires) the tech can tell if the tie rods are bad.
also if you put tires on make sure they check for bent rims.
Porsche rims are pretty stout.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-27-2018, 04:42 AM
EMT/TechRescue Instructor
86911cab's Avatar
Start with rebalancing the wheels.
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 07-27-2018, 07:58 PM
Like everyone else has suggested, start with wheel/tire balance. I had a set once earlier that never could get perfectly balanced; alway had a slight issue at 40-50. Turned out to be the tires. Be sure when you are testing the ride you are on a known stretch that is flat, and you use the same stretch each time.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 07-27-2018, 09:27 PM
Updates
Please provide updates by stage of repair/replacement. I see way too many requests for assistance then silence on the solution, which could help many others. Let us know the fix!
I have a similar problem, I suspect either old tires/poor wheel balance or worn CV joints/lack of fresh grease.
I have a bit of an odd speed dependent roar from the back which could be axles/CV joints in a bind/worn (need fresh grease)? I can kinda “feel” the momentum of the car surge a bit that is commensurate with road speed.
I had an alignment performed a few years ago and the tech said the front end was tight.
Old 07-28-2018, 07:20 AM
Under the radar
Trackrash's Avatar
Agree with most above.
But if it was my car, the first thing I would do is jack up the front end and spin the wheels. Check if the tread runs true. If it is the tire, you will be wasting your time getting them balanced. AHIK.
Good time to check the tightness of the wheel bearings too.
How long has this been going on? On my wife's car there was an imbalance that eventually ruined the front wheel bearings.....
_____________________________________
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-28-2018, 02:13 PM
If your tires are out of round, no amount of balancing will help. At certain speeds, they will synchronize with each other and set up a vibration. A tire shop can check for out of round tires.
They used to have tire truing machines that would cut down the high spots on a tire, but they don't use those machines any more.... just throw the tire away and put on a new one. Tires are being made better these days, so there is less demand for tire truing.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-29-2018, 06:07 AM
