seafood10's Avatar
Is this O2 Sensor connector repairable/replaceable?
I am ready to put the engine back in and was going through the engine bay when I noticed this, what can i do about it?
The wire is still connected but the plastic end of it has broken loose.
84 911 Cab
87 911 Targa
88 930 Cab M505 Slant Nose
62 356B Gone
Old 07-31-2018, 03:16 PM
steely's Avatar
Louie85 was making some replacements - maybe worth a PM.
O2 Sensor connector
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-31-2018, 04:18 PM
+1 on Louie85's solution.
I bought two from him (one for a spare) and installed it. Somewhere along the line, my car was completely jury-rigged with an aftermarket WeatherPak connector and a soldered line to the Oxy Sensor. I now have Louie's replacement connector in the engine bay and a factory style oxy sensor assembly. I feel much better now that it is all essentially stock.
Old 07-31-2018, 04:25 PM
seafood10's Avatar
Originally Posted by steely View Post
Louise85 was making some replacements - maybe worth a PM.
O2 Sensor connector
Thanks, just sent him a PM.
84 911 Cab
87 911 Targa
62 356B Gone
Old 07-31-2018, 04:28 PM
I bought the replacement as well. Mine was completely broken off . But!! If yours has the wire still attached you may want to try some super glue first. I heard some guys fix it that way . Or, buy the new one. Mine works great!
Old 07-31-2018, 07:42 PM
High Life's Avatar
I drive my 81 without the O2 plugged in.. runs great.
1981 911SC
Old 07-31-2018, 08:16 PM
How can I get Louie85's part or is it still available?
Old 07-17-2019, 08:23 AM
I replaced mine with a weatherpack connector. Since the Bosch 02 sensor no longer has the female plug, that end would have needed to be spliced anyway.
The wire connected to the male end is shielded with braided copper, and my understanding is that you can confuse the sensor if you accidentally splice in the shielding with the actual sensor wire. While it isn't factory, it did solve my problem and was relatively inexpensive ($30 or so dollars if I remember for the single pin connector and Packard crimpers).
Hope this can help!
Old 07-17-2019, 10:11 AM
