Differences in SSI models
Hi guys, I have an '83 SC that I am in search of gently used SSIs for. I know for an '83 I would typically use the "thick flange" model.
I noticed SSI makes thick flange exchangers for the '80-'83 3.0 and, under a separate model number, for the '84-'89 3.2. The flange thickness on both models is apparently the same.
My question is are these parts interchangeable? Can I use the 3.2 exchangers on my '83 3.0?
Thanks in advance!
Old 08-08-2018, 07:26 AM
New-ish 911SC Targa Owner
pampadori's Avatar
I thought I'd read that the pipe diameter is larger for the 3.2 SSI's. THen i also thought that I had read Dansk was no longer making both models.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 08-08-2018, 11:49 AM
The insert into the heads would be larger on the carrera boxes.
The C2 boxes are thick flange but no inserts.
Bruce
Old 08-08-2018, 12:26 PM
