72911's Avatar
Yes Another Motorola Alternator Thread
I had my GEN light flicker on the other day while taking a short drive in my 72. I pulled over to look things over in the engine bay but it all seemed Ok. I drove a short distance further and the light came on solid so I turned around to go back to the garage. I used the trouble shooting guide from a post here that said if the light comes on at idle and gets brighter with RPM then it could be a voltage reg. I checked my reg for condition and the vdc at the battery at 1200 RPM was low at 12.3vdc. So I ordered an adjustable regulator and installed but no change. I removed the alt and installed my spare with no change again. I disassembled my first alt and ...well you can see it was completely toast. I also removed my spare and found it to be in the same really bad condition. I sent the first one to a local guy that rebuilds these and installed it last night. No more light! Yea!. I adjusted the voltage at the battery to about 13.6vdc with my head lights on and my AC blower on also. This was the max vdc I could get from the adjuster pot. With the lights off and blower off it is just below 14vdc. I will be driving to Rensport VI in Sept so I am really happy to have this happen only a few miles from home. I am looking forward to the approx 6500 mile trip...just me and my 72....heaven.
72 2.7 Driven!
Old 08-08-2018, 09:55 AM
76 911S Targa
Well done. Great result! Can you post a link for the adjustable voltage regulator?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 08-08-2018, 10:18 AM
72911's Avatar
Here is a screen shot of the vendor. Don't forget that our host here also sells voltage regulators. I wanted an adjustable unit.
72 2.7 Driven!
Old 08-08-2018, 12:18 PM
76 911S Targa
Interesting. Thanks!
Old 08-08-2018, 01:22 PM
