-   -   1987 3.2 Carrera To Do list (http://forums.pelicanparts.com/porsche-911-technical-forum/1004330-1987-3-2-carrera-do-list.html)
danco_ 10-28-2018 06:20 PM
This is what the Recaro cloth looks like close up:
https://preview.ibb.co/j9FGdA/IMG-2437.jpg
madcorgi 10-28-2018 09:14 PM
Originally Posted by danco_ (Post 10231130)
Next up was the interior. There was nothing wrong with it, but there was so much black between the RSA door cards and the Recaro Pole Position Seats. I wanted to change that - bring some color back into the interior.
So I did.
Before:
https://preview.ibb.co/gEbKWV/561341...4-B6453644.jpg
https://preview.ibb.co/kN4jyA/561341...-B9-E1-CD9.jpg
AFTER:
https://preview.ibb.co/f0bWdA/IMG-2623.jpg
https://preview.ibb.co/jVkrdA/IMG-2626.jpg
https://preview.ibb.co/hKMmBV/IMG-2627.jpg
I dig it!
I do too!
Jonny042 10-30-2018 03:33 PM
X 1000!!!
jjeffries 10-30-2018 04:17 PM
Danco, I admire the originality of your interior re-do. Overall your project seems like a state-of-the-art answer to the question, "Show me how to maximize the performance of a Carrera, 2018 edition?". Not inexpensive, really cool. Best, John.
BuddaLun 10-30-2018 04:52 PM
Nice work! Really like the interior and the clean exterior.
danco_ 10-30-2018 09:09 PM
Originally Posted by madcorgi (Post 10231259)
I do too!
Thank you
Originally Posted by Jonny042 (Post 10233559)
X 1000!!!
Thanks!
Thank you! I don't think my end goal is maximizing performance because there will always be someone who is more intensely focused on that goal than myself.
I'm just having fun and personalizing the car while being careful not to add more weight in the process.
Thanks! It gets better every week.
Another shot of the interior door cards, RecaroRS style.
https://preview.ibb.co/dGevcf/Interior-Card.jpg
The final piece for the lightweight battery comes in tomorrow, and then I'll be ready to install that.
I need to think up a new "To-Do" list before I get bored.
danco_ 10-31-2018 07:37 PM
Today was battery swap day.
In there before was a young Interstate Battery weighing in at 43lbs. I promptly removed that mega paper weight in favor of the model ATX-30 from Antigravity Batteries. This battery weighs in at a measly 5.7lbs and with the proprietary mounting kit, a total of 7.2lbs. This nets me a weight savings of 35.8lbs from the front left corner of the car. I figure I can remove the 964 space saver wheel and the tool kit for another 40ish lbs for an easy 75-80lbs of weight savings from the front of the car. That sounds pretty good to me. I should be in the low to mid 2500lb range now (with half a tank of gas).
Before:
https://preview.ibb.co/hNK7A0/IMG-2640.jpg
During. (screwing down the new battery mounting kit):
https://preview.ibb.co/jehSA0/IMG-2642.jpg
and Installed:
https://preview.ibb.co/jxDZq0/IMG-2643.jpg
I realize I positioned the battery incorrectly and covered up the "restart" button on the top of the battery. I'll fix this later.
I drove the car a few times today and I **think** I can feel a difference without the weight up front. Seems like the car is more willing to turn in and just feels quicker and easier to get to speed, and quickly.
I don't have radio or AC or any other potential parasitic draw on the system, so this battery was my choice, while everyone else said to spring for the heavier RS-30 model. I said no thanks. Lighter is better.
So far so good.
Next up, Turbo Fans!
I need to start thinking about a 3.6L Varioram engine swap.
jjeffries 11-01-2018 05:50 PM
Did the battery swap affect/increase the front ride height?
danco_ 11-01-2018 09:39 PM
You know, I haven't checked.
I didn't mention it, but I changed the swaybar end links and a few other things in the front suspension (fresh WEVO top mount load bearings), and it needs to go back in for final alignment. If necessary, I'll have the height adjusted and corrected.
Will report back when this happens.
famoroso 11-06-2018 12:44 PM
Wow! Love what all you've done in a reasonably short timeframe.
Where are you located? Orange County?
I just installed Herr Carceller's modern MAF (in place of a '90s Autothority unit), injectors and ECU this past weekend. As much as I like the stock DME / Motronic... I LOVE the feeling of stepping into the current millennium in terms of MAF & injector hardware. And Sal is uber thorough!
Car feels strong with the new gear and sounds extra pissed at 5k+ RPMs with my pre-muffler and de-baffled (2 of 4) stock muffler.
BTW, is the seating height higher, lower or the same for the Pole Positions versus stock seats?
http://forums.pelicanparts.com/uploa...1541536615.jpg
danco_ 11-07-2018 11:51 AM
Thanks Frank! Yes, I'm in Orange County. In Newport Beach to be exact.
I'd love to see/drive your car to see what Sal's kit is like. Are you in OC much?
Best,
Ryan
Ydobbs 11-07-2018 06:20 PM
Amazing build! Wheel question - what’s the offset on your front 16x8s? Only 8” Fuchs I see have an offset for the rear.
danco_ 11-07-2018 06:36 PM
Front wheels are 16x8 et23.3 I believe. These particular wheels were optional on later 944 Turbo cars. Commonly known as 951 wheels. These wheels clear turbo brakes up front. I don't know of any other 911 wheel in 16x8 that clear turbo brakes.
Hope this info helps.
famoroso 11-08-2018 04:32 AM
Best,
Ryan
Yes. I get up to San Clemente Cars & Coffee occasionally. I'll PM you the next time I head up. I'd like to check your ride out too.
My '87 is rocking 951 8s on the front too. Great setup.
Ydobbs 11-08-2018 06:02 AM
Thank you it does help. I’m now on the hunt to find a set.
Are you using any spacers for the rear?
I have Sal’s MAF kit on my ‘87 as well and I can honestly say it’s been a great experience Working with Sal - and the results are fantastic. I’m very pleased.
danco_ 11-08-2018 09:24 AM
Awesome! I'll be sure to make it down to San Clemented CC when you are coming up. This will be fun. I'll DM you my phone number.
I should mention that the 16x8 951 wheels I have on the front of my 911 are the correct wheels for the rear of the 951 car (944 Turbo).
I have 16x9 (930) wheels in the rear with 12mm spacers, and 16x8 (rear 951) wheels on the front with no spacers. Tires are 245/40/16 rear and 225/45/18 front. I think those are the correct sizes.
I don't think I **need** Sal's kit since my car runs so well, but it's tempting. But at the same time, the plan is to get the 3.6L Varioram 993 engine into this car, so another $2500 towards Sal's kit could be counterproductive in the long run.
I am torn.
Ydobbs 11-08-2018 09:46 AM
Thanks for including tire size. Making some assumptions here while searching Tire Rack - are you running Toyo Proxes T1R's? They show available sizes: 225/50ZR16 &
245/45ZR16.
danco_ 11-08-2018 09:58 AM
245/45ZR16.
Yes, T1Rs on my car now.
danco_ 11-12-2018 09:12 AM
I swapped out the original G50 Shift Joint in favor of the WEVO Performance Shift Joint yesterday AM. Took about 30 min in total, with half of the job being done from inside the cabin, and the other half below the car where the joint meets the transmission.
Before this install, I had the WEVO SSK for some time and I LOVE it. Very crisp, shorter throw shifts. But with the PSJ installed, shifting gears is like a well-oiled bolt action rifle. Exact at every point in the shift. No more slop from the factory rubber bushing between the rod and the factory joint.
VERY nice upgrade for the G50 cars. I didn't think to take photos, though.
danco_ 12-17-2018 06:12 PM
Time to get these Turbo fans wrapped up. I decided on keeping the livery very simple. I have a 917-style key, 917-style shift knob, and I figured, why not go with a 917-style (also 956) wheel fan design. So I landed with this.
https://i.ibb.co/2MN9TYM/fans.jpg
Then I cut out one of them and overlayed it onto the current fan, and I got this:
https://i.ibb.co/VWbYcsC/fans-2.jpg
https://i.ibb.co/GJ400bw/fans-3.jpg
So I can finally give this car a little more style.
https://i.ibb.co/dmstv5t/fans-4.jpg
Should be able to wrap this up next week, though I kind of want to repaint and color match the fans to my car's color Venetian Blue, and go with a white script.
This is the motivation for that color scheme:
https://i.ibb.co/jRD1jR4/autoillustr...64613099-n.jpg
I like where it's heading so far. These fans have been a small but fun project.
