3.2 Carrera dead cylinders post top end rebuild
Hi, All,
It started first go and runs, but cylinders 1 and 2 are dead.
I have checked spark, spark plug wires to correct plugs, and have narrowed it to the fuel injection, I think.
At idle, pulling the injector plugs from 1 and 2 doesn't drop the RPM. Pulling any of the others (including 3) results in a drop in RPM.
I am concluding that perhaps there are 2 bad injectors? I'm going to pull them this evening, but wanted to share my experience in case anyone has any other thoughts.
One other surprise in my checking is that when I measure the voltage on all the injector connectors with the ignition on, both contacts are +12. This is on all of them, including the ones that are working properly.
Yves
1988 Cab
2004 TT Cab
Old 08-08-2018, 06:28 AM
I had the same problem on cylinder number one. I double checked the valve lash, then while covers were off I sprayed KB Blaster on valve adjustment areas of both exhaust and intake. Then I replaced number one fuel injector with a new unit . The last thing I did was to replace the spark with a slightly hotter spark plug. I started car and cylinder came alive!!! It was dead!!! The very first thing I did was check compression and number one was lower than the rest but still in spec.
Old 08-08-2018, 06:44 AM
BTW, I also had 12 volts at number one fuel injector.
Old 08-08-2018, 06:50 AM
With dead cylinders, the first thing you should do is check compression, leak down, then ignition and spark plug, then finally gas. It's somewhere in there.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-08-2018, 06:53 AM
I developed a problem with my 964 3.6 motor. Had trouble on cold start,
but ran Aok when warmed up. Turns out to be a bad connection to the Cyl temp sensor in the large cammed connector block to the ECU. Sprayed DeOxit D5 on the the pins in the connector and ECU, problem fixed. Also had a bit of unstable idle and a bit of hesitation on part throttle. Sprayed all the
connector pins and seated the cammed connector several times, all problems gone! I guess after all the years the pin connections had developed some resistance. I know you have a 3.2, but same type connections. Give it a try, can't hurt. Also the injectors always have 12v,
the injector activates when the ECU applies ground to the injector.
DeOxit D5 is awesome stuff, removes any corrosion and protects from
further corrosion. Used to work in the electronics biz, and it was the go-to
contact cleaner.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-08-2018, 08:08 AM
jamesjedi's Avatar
The above is a great place to start.
Old 08-08-2018, 09:38 AM
The injectors go to sleep when they haven’t run in a few weeks. On start up, if they’re not running give them a slight tap with a screw driver handle. That usually lights them off.
Bruce
Old 08-08-2018, 09:41 AM
theiceman's Avatar
with all due respect i disagree with this as will 99% of professional mechanics.
the first thing you check is spark , always, as its by far the most common cause and easiest to check. requires no tools. ( never mind the fact checking compression is not easy on horizontally opposed engines. ).
Then depending on fuel system could be as simple as pulling out an injector and putting in a jar to check fuel. if not. Then move to compression which will require a compression checker and removing a plug and cranking.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-08-2018, 09:49 AM
jamesjedi's Avatar
I think the iceman is bringing up an important point, spark is easy to check. If the engine has sat for an extended period injectors can fail and need cleaning/testing.
However, this is a top end rebuild. These other items should be checked if the fault is not found.
Old 08-08-2018, 01:24 PM
It's an 84 Carrera, you can do a compression test of that dead cylinder in 10 minutes. And what self respecting mechanic would NOT have a compression gauge that costs all of $35?
in fact when you do this kind of a job, before you put the engine back in, you hook up a battery to a starter and test its compression... as an extra measure of insurance.
Old 08-08-2018, 01:32 PM
gtc gtc is offline
abides.
gtc's Avatar
Check the injector harness, especially at the tight bends.
When I rebuilt my engine at 375,000 miles, the injector harness sleeving and wire insulation had worn away in places, likely shorting out the injectors at times. It was not priviously visible, since the harness is normally zip tied to the fuel rails quite tightly.
Graham
1984 Carrera Targa
Old 08-08-2018, 03:46 PM
Get a noid light and plug into cyl 1 and 2 injector connectors and see if it blinks while cranking. That will tell you if the injectors are being driven properly, eliminate that variable.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 08-08-2018, 04:33 PM
Tap the injectors several times with a small ball peen while it's running. Those injectors can stick after sitting dry for a while.
206 637 4071
Old 08-08-2018, 09:03 PM
Thanks to all who chimed in. Noid light showed all was well, so I whacked the two injectors a couple times and all was perfection. Super satisfying to complete my first 911 R&R!
1988 Cab
2004 TT Cab
Old 08-08-2018, 09:49 PM
theiceman's Avatar
agreed, but you can check spark in 5 seconds.
Also it was stated ALWAYS check compression first, I was giving a different perspective
Old 08-09-2018, 07:22 AM
