shock strut rocking
Just changed my front wheel bearing because i thought the where worn out, when grabing the tire 12 and 6 a'clock i could hear and feel a rocking. But it diddent help
![]() Found out that the rocking came frome the shock. The shock that goes into the strut is moving when i grab the wheel 6 and 12 o'clock ( see picture) Is looks like the shock goes through a rubber gasket before i goes further in to the strut. Is it normal to have this play or do i need to replace a part? |
Member 911 Anonymous
Is that a bilstien HD insert? Going into which housing?
There is a fix but we need a bit more information.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
in addition to the rubber seal there is a bushing in there, if it's worn out if can cause the rocking you're describing, it should be replaced
Yes it is a bilstein shock in a bilstein housing with a pin in the botton.
Where do i buy a new bushing? |
cycling has-been
I'd start with Ira at Tarett.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
We sent our Bilstein struts to Cgarr in Mich to replace the inside bushing . . .
Craig Garrett 5424 Greenboro Dr Grand Rapids MI 49508 garrett@iserv.ne Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
I got the same issue with new b6's in bilstien struts.
Wondering if this is a dyi, or do I need to send this to someone.... Paul
'78sc coupe / 89 Westy - EJ25 frankenmotor |
Thanks, but if you look at my location i live in Denmark
Thought i was a replacement part i could buy |
The bushing and seal top are items that Bilstein can sell you separately. We have purchased them in the past, but unfortunately it was so many years ago, I can't help you with part numbers. You need to contact Bilstein technical service department for assistance
good luck
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
cycling has-been
Wait, what - you have no phones in Denmark?
bkreigsr
No we don't have phones anymore, we use mobils now
