JED
ARCSinAK's Avatar
19mm Rear sway round clear bushing install tips?
Tried lubing the clear bushing up and using a C clamp but seemed like I was deforming/smashing the bushing. Any advice on this step of the instal?
Old 08-13-2018, 11:08 PM
Used a pair of channel lock pliers to get the bushing into the drop link, C clamp to install onto the ball.
77 911s
16 981gts
Old 08-14-2018, 05:07 AM
cycling has-been
bkreigsr's Avatar
Here's how I do it.
Use a vise to press the grommet into the link. (help the edges with a screwdriver)
Do a false install and align the grommet to the ball in the swing arm.
Prop up the sway bar to the height of the ball.
Cut a broom/mop handle to somewhere around 13 inches.
Align the broom handle with the grommet and give it a few good whacks with a 3 pound hammer.
If it's the first time install for the grommet - it's going to take some extra effort, but it will go in.
Bill K
Old 08-14-2018, 10:16 AM
JED
ARCSinAK's Avatar
Sure appreciate the tips. Going to weld on the brackets this AM.
Old 08-14-2018, 10:24 AM
Not unlike installing the support bushing at the front end of the shift tube.
Clamp the drop link in a bench vise, then use large “Channel Lock” pliers to squeeze it into place. Heating it in hot water should also make it more pliable.
Sherwood
Old 08-14-2018, 12:17 PM
