Both turn signals and emergency flashers don’t work.
I read about this problem here and subsequently ordered a new flasher from pelican.
Bizarrely, when I looked in the space behind the gauges from the frunk I saw ‘a little platform’ which looked perfect to pop the flasher on. I looked around and wondered where the potentially faultly one went?! I plugged the new one in and tried it: the oil light blinked!
I’ve tried multiple times to add a photo here with my iphone but to no avail. Anyone figure out what I’m talking about? Can you point me in the right direction?
Thanks, Greg
1978 911SC
Old 08-14-2018, 08:47 PM
Old 08-14-2018, 08:48 PM
Green one is the ‘little platform’. Not sure what’s in the blue circle?
Old 08-14-2018, 08:49 PM
Heck, I’m only 5 not 71!
targa80's Avatar
I believe the empty plug is for the seat belt buzzer. When you put the key in the ignition you would hear a buzzing sound? Many owner's find it annoying and remove it. The other relay in the blue circle should be the flasher relay to be sure check the part number on the relay.
Below is a link to a thread on the flasher circuit that may provide insight and the schematic for the circuit.
Flasher/Hazard Mods on my 80SC
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-14-2018, 09:10 PM
7783911's Avatar
mine ended up being a ground issue with the parking lights,,,fixed that and all was good again
Old 08-15-2018, 03:58 AM
had the same issue, but mine was a pinched wire in the rear signal box. it would work and then randomly blow fuses, sometimes days apart, sometimes immediately...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 08-15-2018, 08:44 AM
theiceman's Avatar
yeah id be cleaning up the mouse droppings and looking for the perpetrator before your problems get bigger.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-15-2018, 09:06 AM
maybe some chewed wires?
Old 08-15-2018, 10:07 AM
targa80's Avatar
I just noticed the mouse droppings in the pic. My car Sat for 10 years on a car lift found a nest in the air intake. The wiring harnesses were stored separate from the car so so their was no tasty insulation for the critter. When I finally started the car up the exhaust shot out empty bird seeds.
Pat Henry
Targa80
Old 08-15-2018, 02:14 PM
