Looking for this engine and trans. lost it in 1979. Just purchased #3281590 last night.http://forums.pelicanparts.com/uploa...1378318341.jpg
engine serial number 901561, build number 1461
901/01
Don't know if your still keeping a register but i have a 2.0L Porsche engine Type 901/01 with Serial # 902862 Build # 2762.
Yes, I keep checking and adding to my database.
68 L aluminum cast case
Had aluminum chain boxes and 68 casting numbers on the cam carrier with 11 nut exhaust valve covers.
Was in my possession for a short time Bruce http://forums.pelicanparts.com/uploa...1447122428.jpg http://forums.pelicanparts.com/uploa...1447122445.jpg |
Thanks Bruce, every datapoint helps. Dave
Dave
Can't remember if I sent you this one. Tell me about it. http://forums.pelicanparts.com/uploa...1447167536.jpg http://forums.pelicanparts.com/uploa...1447167596.jpg http://forums.pelicanparts.com/uploa...1447167611.jpg |
Bob, that is very interesting. I had the VIN & engine # but that was it.
Nice to confirm the build # with a photo. The AC installation is very unusual. Would probably be worth getting the Kardex; contact me please. |
vin and production numbers
hi dave,good to see your still working on your data base,haven't heard from you since last sept,when i sent you pictures of production and vin#s,just wondering if your contacts or data base had yielded the missing vin number,best,SmileWavy frank.
I have some engine info:
Number 907303 Type 901/05 Build 4159 Is it a '66? Thanks, Kevin |
couple more numbers
2081572 901/03 15477
4080375 901/02 10604 |
901/14 case no
901/14 11188 blank case - aluminium
901/14 10665 3230302 - aluminium both engines without cars in the moment |
901/14 case no
901/14 10665 3280302 - aluminium both engines without cars in the moment |
Kevin, definitely a 1966 Model Year
Larry, thanks! Kim, 11188 should not be blank; is there evidence of the serial being removed? The original serial is likely near 3280433 +3/-7 |
http://forums.pelicanparts.com/uploa...1488049486.jpg http://forums.pelicanparts.com/uploa...1488049486.jpg |
Dave, I though I gave you my info before but I don't see it on your list. Eng s/n 6392032 type 901/10 build # 25955
Mark |
Hi
I bought a 1968 2 liter yesterday here in Norway. Used to be in an old VW bus some years:D Type 901/03 with Serial # 2080404 Build # 11028 http://forums.pelicanparts.com/uploa...1537424371.jpg http://forums.pelicanparts.com/uploa...1537424371.jpg http://forums.pelicanparts.com/uploa...1537424371.jpg |
Thanks guys. Just a reminder that the most up to date list is found here; I can update this thread easier since Pelican posts cannot be updated a after a short period. When possible please look for the case mating #,s on the top of the case near midpoint, and the casting dates under the pulley on each half.
Type 901/xx Engine Build #'s |
| All times are GMT -8. The time now is 08:31 AM. |
