1978 SC won't start
HI, I have just purchased a 1978 SC project non runner.
I have cleaned the fuel tank,changed the fuel pump/filter and relay and now have fuel to the injectors. I can hear the CDI unit but there is no spark. Can anyone help? |
could be the coil . is it Silver ? if it is it is definitely the coil.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
just because it buzzes, does not mean it works. Figure out the CDI first.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Fleabit peanut monkey
Borrow one from the neighbor's 67 Chevy sort of logic. It's a shortcut, surely. But not the worst "throwing parts at a car" error given the meager cost.
1981 911SC Targa |
no, shot gunning a coil is not always a bad idea. if they are both good, then you have a spare to carry with you because it eventually will fail.
you can get a MSD for about $60.
A humming CDI could still be bad. As a first measure check the coil's primary and secondary resistance. I don't have the exact numbers at the top of my head but it's something around 1.0 Ohm (give or take) for the primary, and 1 - 1.5 kOhm for the secondary. If one is open it's the coil.
Next, it could be the trigger wire from the distributor to the harness. This is a COAX cable and if there is any fraying chances are it's bad. Unfortunately, testing the CDI box is not really straight forward unless you want to build small extension cables for the 6-pin connector. In that case you need three wires (GND, +12V and COIL) to go between the 6-pin harness connector and the box. Then connect another set of wires to the second GND and trigger input of the box. Finally connect a spare spark plug to the coil output and ground it to the engine. With power to the box you can trigger the box with an AA battery: + of battery to GND of box touch - of battery to TRIGGER of box needs to release a spark A word of caution. A damaged box is able to put out up to 450V onto the coil primary (if the coil primary is open). So once the system is humming it CAN be live. That's the reason for the yellow warning sticker on the box. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Spark
Confirm that it is a no spark issue, I thought it was a no spark issue, I swapped coils, etc., with no luck on my ‘82 SC . I looked in low light and saw a little spark.
It turned out to be a blown out pop off valve (old hard glue/epoxy) after a very mild backfire - so mild I didn’t think it could be the pop off valve, and I had a pop off valve which is supposed to prevent this issue... |
In many instances in my life, it's been as simple as the coil wire - either corrosion or breaking down (or not stuck in all the way).
Six months ago my '78SC refused to start. So first confirmed no spark by using a spark plug resting on the engine. Then followed CDI checking procedure in Bently Manual; photo of relevant page:
My understanding of spark generation on this car is as follows: the distributor generates a small voltage pulse which you can check by following above. The CDI transforms this to 400 volts which is then relayed to the coil which ups it to 20,000 volts. There could be a problem anywhere on this route. For example there is a connector to the green wire behind the distributor so you can also check there for the pulse if you don't get it at the CDI end of the cable. In my case it was the green wire: Bentley suggests distributor is faulty in absence of pulse but in my case it was the green wire, confirmed by pulling the distributor and bench testing: distributor gave a pulse when rotated by hand. Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
