trying to find color number
Is this the right forum to ask where the color code is located on a 1969 911E? Is it on the stainless piece under front hood with vin and reads Dr. Ing Ferry Porsche? thanks in advance
Old 08-20-2018, 01:23 PM
It should be stamped on a smallish metal tag that's riveted to the front of the drivers side door jamb, below the light switch and above the check rod.
Old 08-20-2018, 11:28 PM
Thanks, I'll get looking!!
Old 08-21-2018, 05:45 AM
HarryD's Avatar
This is the tag you are looking for (from another persons post):
Originally Posted by earlyaircooled View Post
here is a copy of the vin tag
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-21-2018, 04:11 PM
Found it. Metallic Green. The number above it I presume is the body Number? My paint code is stamped in very bold, the other number I can't even see a trace. One owner car, never painted or had this plate removed. Why is there no number there? Also, what does M8 represent. Thanks guys!!!!
Old 08-22-2018, 06:07 AM
HarryD's Avatar
No one be the deal with the “M8”. It is a mystery.
Please post a picture of the plate.
Harry
2020 MB E350 4Matic
Old 08-22-2018, 06:25 AM
plate pic
Here is the plate. M8 is stamped into body above this.
Old 08-22-2018, 06:28 AM
HarryD's Avatar
The L at the end indicates the paint was made by Lesonal
You can look at colors here : https://members.rennlist.com/tweedt/glasurit.htm
Harry
2020 MB E350 4Matic
Old 08-22-2018, 08:37 AM
djpateman's Avatar
From 1969 the VIN was not stamped on the paint badge.
The L on the paint code is for Lesonal, the paint supplier.
The M8 may be related to the bolt thread size of the hinge bolts, but why is not known.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-22-2018, 08:43 AM
