scca_ita's Avatar
Trailing arm Bearings vs. stock bushing
I am going to coil overs and for the rear trailing arms I was considering replacing the rubber bushing with bearings.
I also will use a new 935 spring plate.
Is this over kill for a car which is dual purpose track/street?
Old 03-04-2003, 07:31 AM
Chuck Moreland's Avatar
IMHO, inner trailing arm monoball bearings are a no-brainer with your setup.
Coils and 935 spring plates is a serious setup. To pair that with rubber bushings doesn't make a lot of sense. Sorta like skipping to the advance stuff without covering the basics.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-04-2003, 08:38 AM
