Ignition key problem
Hi,
In as three ocassions I’ve noticed when I try to start the car if it doesn’t start the first few turns I would return the key back to start position which should cut the starter out but instead the starter continues to run. Even removing the key has no effect, once it starts it’s ok .
Has anyone seen this problem?
Thank you
1974 911 coupe 4 speed
Old 08-20-2018, 04:16 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Key.
You may want to try some lock lubricant.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-20-2018, 04:20 PM
Chewed up starter ring gear teeth and starter bendix teeth can get stuck together, which holds the solenoid internal contacts together without any need for activation voltage from the key.
206 637 4071
Old 08-20-2018, 05:06 PM
