Coloradocurt's Avatar
Transmission Fluid
Is there any "generally favored" transmission fluid for the 915 5-speed (non-racing applications)?
Old 08-29-2018, 02:07 PM
Many threads on this topic all of which end in 80w90 Kendall or Swepco 201. Those are the most popular and generally accepted as fine choices.
Old 08-29-2018, 02:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
...and depends if you have Standard or Limited Slip Diff. Check the serial number of the bottom of your gear box.
'85 Carrera Targa
PCA/POC
Old 08-29-2018, 02:24 PM
Thanks. My guess is that it's a Standard as it's a very nice, original 1973.5 911T (I'm getting next week). But other than the model number on the bottom of the tranny, what would be the give-away to answer the Standard vs LSD question. Or is the model number in-and-of-itself indicative of the answer to that?
Old 08-29-2018, 03:10 PM
Navin Johnson
TimT's Avatar
With the car on a lift, or both rear wheels jacked up rotate one of the wheels,
Observe what the wheel on the other side does... if it rotates in the same direction, you have a limited slip...
If the opposite wheel rotates in the opposite direction you have an open diff..
I'd wager your car has an open diff..
'69 911 GT-5
'75 914 GT-3
and others
Old 08-29-2018, 03:22 PM
If the model/serial number on the trans has a 12 between the model
and serial number it has LSD. EX: 915/73 12 12345
No 12 no LSD unless it was added later.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-29-2018, 03:35 PM
gearhead
Most of them are, and I can't say that I've ever seen a T spec'd with an LSD.
Agree with the above about oils. People here argue about Kendall versus Swepco like their lives depend on it, but it doesn't matter. Either works.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-29-2018, 03:40 PM
I have had good success with Kendall, hell so good it let me go from 3rd to 2nd at close to 80 mph with ease!
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 08-29-2018, 03:48 PM
Bill Douglas's Avatar
Handy helpful hint time. Before you drain the old oil out of the gearbox, make sure you can undo the filler hole on the side. Looking forward to seeing pic's of the new car
Old 08-29-2018, 03:50 PM
72911's Avatar
I have used both Kendall and Swepco on two different boxes. One 7:31 and one 8:31 that I use for Grant Touring. Both boxes are original unrebuilt units and they both shifted EXACTLY the same. Both need lots of TLC when shifting and lots of double clutching (even triple when cold). I seem to have more leaks on the 8:31 Kendall box. I have had both boxes apart to inspect and just re-assembled with new gaskets since they both seemed to be in fair shape. My 2 cents.
72 2.7 Driven!
Old 08-29-2018, 03:53 PM
I just did this for the first time this weekend. Very easy, just a bit messy. I used Kendall and there has been a nice improvement in shifting. I was also unsure about whether I had an Lsd, but as I had to jack the car anyway I just checked by turning one wheel and watching the other. Best tips were to undo the fill plug first and heat the oil in hot water before filling. With the cheap pump from Pelican it only took about one minute to pump each quart
Old 08-29-2018, 04:23 PM
I use Swepco in my 915's and Motul in my G50's.
Old 08-29-2018, 04:26 PM
Red Line Service
Marc Bixen's Avatar
We love Kendall at Red Line. As for LSD or not, always go by the manual test, turn the wheels. We've worked on LSD cars with no LSD in them.And we've installed LSD's in many, DON'T GO BY THE TRANS NUMBER, parts can be changed. LSD additive will not hurt anything.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 08-29-2018, 04:33 PM
In my very high mileage 915 Kendall helped the syncros align in 1st and 2nd, easier shifts, and better cold morning driving. used both, Kendall is a bit cheaper too.
Old 08-29-2018, 07:19 PM
Same for me in my kinda high mile SC.
Old 08-30-2018, 10:09 AM
