Targa_PB_78_SC
mike sampsel's Avatar
CIS removal questions and help please
Well I've removed all the nuts to the runners and things are somewhat free.
The passenger side is the most loose. The drivers side is a little fidgety.
I plan to add a wee bit of grease to all the bolts to the runners to aid in the extranction process.
1.) Is adding a little grease here okay? White lithium is my plan.
2.) There are a couple of electrical connections at the rear of the airbox/CIS per the attached. Do both of these need to be removed to remove the CSI system.
Here ...
and here are the connections remaining. Oops likely same connection with different angle. There are two connections though. Disconnect I will ...
3.) The WUR still adds weight to the CIS removal. All the lines are disconnected except the one which runs fuel to the center of the fuel distributor. Can I/Should I remove the line and if so should I remove it off the WUR side?
Disconnect at the green or leave it alone?
4.) Is there a trick to prying the runners/airbox off?
5.) Do the aluminum tubes shown in figure below (in the red oval) come out with the CIS?
Old 08-23-2018, 10:43 AM
Steve F's Avatar
Thumbs up
Lots here to help with your questions:<)
https://forums.pelicanparts.com/porsche-911-technical-forum/700716-removing-cis-engine-car-writeup.html
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 08-23-2018, 10:51 AM
Targa_PB_78_SC
Originally Posted by Steve F View Post
Thanks,
Yes this is a removal taking the airbox off the runners.
But the photo does answer some of my questions.
I'm a little different.
Old 08-23-2018, 11:46 AM
Steve F's Avatar
Is your engine out or in the car?
Old 08-23-2018, 12:15 PM
Targa_PB_78_SC
Well the CIS is now out of the engine compartment. There was a bolt clamping the fuel injector lines to the back of the airbox and then down to the plate with the throttle linkage.
This made the runners of the driver side difficult to move because the box was secure.
So far the only casualty is the loss of the spring which ran from runner number two to the throttle bracket.
How hard can it be to find it?
Obligatory photos follow:
Location of the bolt which secured the airbox to the plate and was not easily found.
Old 08-23-2018, 04:37 PM
Steve F's Avatar
Old 08-24-2018, 04:56 AM
