Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by darrin View Post
I'd strongly suggest at least inquiring into the cost of drilling the heads for a second plug (and capping the tapped holes).
When I sent my heads to EBS in the way-back, the cost was not prohibitive. Don't remember exactly, but not a back breaker financially.
Just talking. I had a cylinder head sensor port machined into my #6 cylinder. I think it was $60, 1997 money.
1981 911SC Targa
Old 09-04-2018, 01:33 PM
trakrat ---
1) more detonation clarification -- believe the key here (and I'm not an expert) is preventing preignition of the fuel, which is exacerbated by the longer path the spark-ignited fuel needs to travel in a wider, larger displacement cylinder. Hotter spark may help a bit, but what you're fighting (and what twinplugging will most effectively fight) is spontaneous ignition of the fuel at the far side of the cylinder before the sparkplug-ignited fuel lights it off -- spontaneous ignition at/before the piston reaches tdc is BAD.
2) compression -- octane is a measure of a fuel's ability to resist knock/preignition. Euro engines have higher compression because european gas formulations generally have a higher available maximum octane level than the US (requiring lower compression to avoid knock/preignition)
3) weight -- unclear why this is an issue. A 3.4 liter engine will provide room for more fuel/air to collect in each cylinder, resulting in a bigger explosion pushing the piston down (and therefore more power / torque). Component weight may come into play in some manner, but the justification for a bigger engine is a bigger "bang."
Old 09-04-2018, 01:42 PM
Unfortunately Bob... the heads are on their way back to me after getting everything done to them.
Besides that... adding all the costs to setup a twin plug (new distributor, etc...) makes things get expensive quickly.
It's not that I "won't" go to a twin plug... its just that I'm not ready. I've only driven the car for about 4 months before I had to rebuild the engine... and once that's done.. I'll ne to rebuild the suspension... and fix rust... etc...
I figure, since I'm rebuilding the engine and have to buy a new set of P&C... I thought I'd go with something slightly better than what the car came with.
But maybe that's not an option? It seems that if I don't get twin plug... then I should admit defeat and face the reality that I should just buy another set of factory 3.2 P&Cs?
1987 Porsche 911 Carrera Coupe
Old 09-04-2018, 01:45 PM
Hilbilly Deluxe
emcon5's Avatar
Call EBS racing and see if they can source you the 98mm Mahle Max-Moritz style pistons you need. They can machine your stock cylinders to fit.
82 911SC Coupe
GTI Cup #43
Old 09-04-2018, 02:03 PM
emcon5 -- good advice -- seems the key here is to go with a proven, middle of the road, setup and there are plenty of single plug 3.4l engines out there. Go with what others have successfully used in the past and don't try to "reinvent the wheel" -- Trackrat, also keep in mind that once done, you'll need to get a chip mapped to provide proper afr to your now bigger/thirstier engine
Old 09-04-2018, 02:07 PM
Bob Kontak's Avatar
Agree.
Would be cool to have that as a hip pocket option down the line with the machine work already done.
Do call EBS and just yak with them. I like the 3.4 option. Don knows his stuff. Jon is the boss but I don't think he works the phones like in the way back.
1981 911SC Targa
Old 09-04-2018, 03:10 PM
trakrat -- if you're committed to running 100 octane gas all the time, you should have zero issue going with eurospec pistons (or much higher compression 3.4 pistons than would ordinarily be run on a car running on pump gas) -- 100 octane has much higher anti-knock properties than 93 octane pump gas.
I echo Bob Knotak's suggestion of discussing this with somebody knowledgeable about this particular issue -- somehow missed your comment about your being dedicated to running this motor on 100 octane gas exclusively
Old 09-04-2018, 04:20 PM
T77911S's Avatar
i see you referring to what Porsche did. they did not do things based on 100 octane fuel.
no one has considered the fuel you plan to use so I don't think much of the advise has been helpful.
100 octane opens the door for you.
start with fuel as I said,
figure out engine size, CR and cam based on the fuel.
with 100 octane you might be better of with a 3.2, higher CR and a cam that will work with it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-05-2018, 03:53 AM
fred cook's Avatar
Big Bore Pistons
When I built the 3.3SS for my SC, I used a set of Mahle 100mm pistons. They were supposed to be 10.1:1 but wound up closer to 10l8:1, probably due to the heads being cut one or more times. These pistons have a nice, low, hemispherical dome that is less likely to block the flame travel. I am using twin plug ignition, but if you stayed under about 10:1 premium pump gas should work ok. Some pictures:
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-05-2018, 05:49 AM
fred cook's Avatar
Twin Plug ignition..........
I used the Electromotive XDi twin plug, crank fire system. It not only is completely adjustable for timing, but eliminates the distributor completely. No expensive distributor caps or rotors to buy come tune up time! A tune up on my twin plug engine consists of an oil change, filters and 12 spark plugs! Plus, deleting the dizzy really cleans up the engine clutter! Cost for the system was about $1300.
Engine running with no distributor!
FEC3
Old 09-05-2018, 06:02 AM
Cory M's Avatar
so WHAT is considered high compression then?
I'm told that anything above 10:1 compression needs twin plug... if so.. then did Porsche twin plug their Euro spec cars from the factory to support the 10.3:1 compression that their factory spec P&C?
I was planning on buying the Mahle 3.4 P&C set... but then I noticed the weight of the 3.4 is heaver than the 3.2... which made me wonder if I would be gaining anything worth the price of going to 3.4
I raced a single plug 10.5:1 3.4 with JE pistons, on 100 octane fuel, for several years. I also raced a 3.2 with the same fuel and comp ratio. My street SC is a 3.2ss with 9.5:1 compression and runs on 91 octane, also single plug. Both engines were built by Supertec. We've got another Carrera based single plug race engine with over 11:1 and it runs 110 octane. So in my experience those are about the limits for single plug: 91 octane - 9.5:1 or lower, 100 octane - 10.5:1 or lower, more than 10.5:1 and you'll need 110 octane and/or twin plug. A good engine builder can provide more info I'm sure, but that's my experience.
Old 09-05-2018, 06:21 AM
Chain fence eating turbo
Just send your heads to "cgarr" for twin plug. You won't regret it.
You don't have to add the 2nd ignition right away, and can add later. You'll sleep better at night!
Detonation sucks!!!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-05-2018, 07:06 AM
agree -- even though they're in transit back from being machined, better to incur the (relatively minimal) expense of having the heads ready for twin plug IF needed then to disassemble the top end to pull the heads post-rebuild.
Wonder what the "over/under" would be mileage-wise between the premium paid for 100 octane gas and the additional expense necessary to twinplug and run pump gas?
Old 09-05-2018, 08:11 AM
Well I talked with EBS Racing to see what option I have... and apparently quite a few when talking about custom JE pistons.
I need to get my heads in to do some measuring to get back with Don @ EBS racing to see what would work best.
Old 09-05-2018, 11:34 AM
sp_cs's Avatar
10.0:1 Mahle 98mm single plug pistons are available - you’d need to decide on the single v twinplug though. They’d be single plug for sure in UK.
https://www.*****************/fu/prod137451/Piston-engine-set-Porsche-911-CARRERA-32L-to-34L--1984---1989--Motronic-inj---98mm-/
Shirish
1987 Carrera, Granite Green
Old 09-05-2018, 12:33 PM
