1987 Fuse box diagram help
Could someone please post or tell me where I might find a picture or drawing showing what each fuse and relay is for
in my 1987 Carrera? Yes, I tried to search.
Also, why would the cooling fan for the oil cooler always be on when the key is on?
Thanks in advance.
Old 07-04-2005, 11:40 AM
nreed's Avatar
give me your email and I'll send you all the schematics.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 07-04-2005, 11:44 AM
nreed's Avatar
woops...I thought you had a turbo. I can still scan in the carrera fuse block diagrams.
Norm '86 930
Old 07-04-2005, 11:46 AM
another round please
strupgolf's Avatar
is it not on the inside of your fuse box cover? My 86 has a diagram there telling me what fuses go to what. 2cworth.
Getting old is not for wimps.
Old 07-04-2005, 01:52 PM
No. I don't have anything inside my box cover. That's why I need help.
Thanks.
Old 07-04-2005, 02:48 PM
Seeeu911's Avatar
This is great !
nreed, I also have need for the fuse diagram ! can you please email me scan as well ?
seeeu911@hotmail.com
Thanks !
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 07-04-2005, 02:55 PM
Used Up User
imcarthur's Avatar
Here's a Bentley scan. Probably a worthwhile purchase for you.
Relays to follow. . .
'87 Carrera Cab
Old 07-04-2005, 03:02 PM
Used Up User
imcarthur's Avatar
'87 Carrera Cab
Old 07-04-2005, 03:06 PM
Seeeu911's Avatar
thank you very much imcarthur, agreed ...the Bently is on my short list to purchase.
to help you unravel
Old 07-04-2005, 03:08 PM
Thank you. I knew someone would have it! I have a Bentley on order.
Thanks again!
BSD
His toys -
Saving for the next 911.
2007 Mazdaspeed 6
Her toy -
1994 Miata Limited Edition
Old 07-04-2005, 03:12 PM
porsche cabriolet 1987
my convertible roof wont close :-((...i suspect the fuse...can someone tell me which fuse is guilty? i have no extra fuses therefore i will make a switch until the stores open tomorrow. which fuse can i switch around to be able to close the roof urgently?? thanks for your help..
Old 04-10-2015, 05:17 PM
Certified User
billjam's Avatar
It is the 25A fuse, third from the rear of the fuse box.
You could swap out any of the other 25A (blue) fuses except for the fuel pump fuse (6th from the rear).
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 04-11-2015, 07:44 AM
doc911's Avatar
Dear imcarthur,
It might sound a bit too late but, thank you very much, indeed for the chart.
I've recently used it in my 1987 Carrera Cabriolet.
Fahad
Old 09-15-2018, 08:47 AM
doc911's Avatar
Dear imcarthur,
Fahad
Old 09-15-2018, 08:51 AM
