1987 Fuse box diagram help
Could someone please post or tell me where I might find a picture or drawing showing what each fuse and relay is for
in my 1987 Carrera? Yes, I tried to search. Also, why would the cooling fan for the oil cooler always be on when the key is on? Thanks in advance. |
give me your email and I'll send you all the schematics.
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
woops...I thought you had a turbo. I can still scan in the carrera fuse block diagrams.
another round please
is it not on the inside of your fuse box cover? My 86 has a diagram there telling me what fuses go to what. 2cworth.
Getting old is not for wimps. |
No. I don't have anything inside my box cover. That's why I need help.
Thanks. |
This is great !
nreed, I also have need for the fuse diagram ! can you please email me scan as well ? seeeu911@hotmail.com Thanks !
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
Used Up User
Here's a Bentley scan. Probably a worthwhile purchase for you.
![]() Relays to follow. . .
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Used Up User
thank you very much imcarthur, agreed ...the Bently is on my short list to purchase.
Thank you. I knew someone would have it! I have a Bentley on order.
Thanks again! BSD
His toys - Saving for the next 911. 2007 Mazdaspeed 6 Her toy - 1994 Miata Limited Edition |
porsche cabriolet 1987
my convertible roof wont close :-((...i suspect the fuse...can someone tell me which fuse is guilty? i have no extra fuses therefore i will make a switch until the stores open tomorrow. which fuse can i switch around to be able to close the roof urgently?? thanks for your help..
Certified User
It is the 25A fuse, third from the rear of the fuse box.
You could swap out any of the other 25A (blue) fuses except for the fuel pump fuse (6th from the rear).
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S Last edited by billjam; 04-11-2015 at 07:48 AM.. |
Dear imcarthur,
It might sound a bit too late but, thank you very much, indeed for the chart. I've recently used it in my 1987 Carrera Cabriolet. Fahad |
Dear imcarthur,
