Glasgow 911SC's Avatar
Richard,
Cheers for the offer! I need to get the car back on the road though ASAP or I'm stranded. I was looking at the prices for bigger bars and Pelican has sway away ones at a good price. After spending £700 in the last week though, leaves me kind of skint! It would have been an easier decision to make 2 weeks ago!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 03-05-2003, 02:14 PM
dickster's Avatar
chris
if you want to upgrade in the future theres not much point spending good money on new std bars. how about a secondhand one? at least the front are real easy to swap.
Rich
'86 coupe
"there you are"
Old 03-06-2003, 12:34 AM
Ok, a bit of an update.
T-Bar is snapped.
This morning I tried to remove it but the belly pan is frozen in place! I've managed to sheer off one of the front mounting bolts Are these bolts or is it a stud? What size?
I removed the T-bar cover/adjuster and pulled the piece out.
The picture makes it look worse than it is but there is a fair amount of surface rust on the bar. I'm pretty sure they're the originals.
I've got a new pair on order as it would be a long while before I can afford to upgrade front and rear to 22/28.
Chris
Old 03-06-2003, 06:46 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Whew! That's some shear alright!
Is the bar stuck in the cap in that picture or no?
Hope you can reuse the cap and the screw. Neither are cheap. (based on cost to size ratio)
Kevin L
'86 Carrera "Larry"
Old 03-06-2003, 07:52 AM
Eric Mckenna's Avatar
WHAT THE **** HAPPENED THERE!!!!!!!!!!!!!!!!!!!
Originally posted by Planter91C2
sweet god all mighty!!!! what ... who.... how....
aarrgghh! what happened!!!
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 03-06-2003, 08:05 AM
No, the bar is just sitting there for the picture. The only damaged part is the forward bolt/stud that holds the belly pan on that I just snapped off this morning. The rest have been WD'd to loosen them up. Hopefull once the pan is off, the other end will come out without too much of a fight!
Chris
Old 03-06-2003, 08:06 AM
