Cup1 Wheel Offset
Hi All
Never having seen an earlier 23mm vs 47mm offset wheel side by side for comparison, I was wondering where the offset is created? Is the back mounting surface or are the spoke face different for the same width rim?
TIA
Old 09-16-2018, 09:57 AM
Bill Verburg's Avatar
Originally Posted by Porshaah View Post
Hi All
TIA
ET or offset is the distance from the wheel center line to the mounting face
+ means that the centerline is inboard of the mounting face
- means that the centerline is outboard of the mounting face
0 means that the centerline matches the mounting face
additionally the back side of the spokes and hub can be shaped differently to provide more or less brake room
for instance 911 7" Fuchs and 944 7" Fuchs have the same ET @23.3, meaning that the wheel centerline is 23.3mm inboard of the mounting face. But the 944 wheel has a center section that is shaped to provide considerably more room for bigger brakes.
When mounted on a car the only visual clue as to which wheel is used is seen at the bolt holes
Bill Verburg
Old 09-16-2018, 12:12 PM
proporsche's Avatar
here is my front 8th offset
and rear 9th offset
1985 911 with original 502 191 miles...808 198 km
Old 09-16-2018, 12:27 PM
I understand the concept, I'm just not familiar with how, specifically, the OEM/Factory Cup1 (i.e. not Fuchs, Cookie Cutter, Phone Dial etc. just to keep things simple and it's all I'm interested in) early and late wheel differ in appearance. In other words, do the spokes protrude further past the face of the rim on a 47 than a 23 ET of the same rim width?
Again
TIA
Old 09-16-2018, 01:32 PM
Again
TIA
The ET23 early offset repro Cup1 wheels and the 47ET wheels externally
look identical. The difference is looking from the rear of the wheel.
The ET23 has much longer protruding mounting surface whereas the ET47 wheel has an almost flat mounting surface. Ergo the difference in ET
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-16-2018, 03:08 PM
Thank you Uwanna and all, for your responses.
Old 09-17-2018, 06:36 PM
