Where can I get cadmium plated motor mount bolts for a 86 Carrera
Post say's it all.
Brew Master
Google says you can buy one from Pelican Parts
Part #: 900-082-142-01-OEM
Nick |
abides.
You could have yours replated by Shaun.
Graham 1984 Carrera Targa |
Get the Caswell Plating kit and a small crock pot at WalMart. New Zink bolts can all be turned to Yellow in your garage.
https://www.caswellplating.com/yellow-chromate.html
Derrick |
I had the same problem. I got these bolts from Belmetric and they are yellow zinc. BTW, they are a little longer at 35mm but then you can use washers and a proper locking bolt rather than crap split washers.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 Last edited by Snitzler; 09-18-2018 at 01:52 PM.. |
I'm good with the small bolts. I need the long bolts through the center.
