Seth Hamilton
Converting Turbo flares to RS- Help needed
I am looking at an SC that had turbo flares welded front and rear. I would like to return it to an rs or r spec with a backdate. The car is a great platform for the backdate other than the turbo flares. What additional work would be required to narrow the body other than what is typically involved with having to weld on the new RS flares? I guess asked another way - Can turbo flares be cut off and RS welded on without needing to replace the quarter panel, or some sore of similar major effort? Worst case seems to be cut off turbo flares and order carbon panels.
Thanks for the help.
Collector of stuff most don't care about.
Garage- 2018 GT3 (6spd,LWB, Chalk). 69 911t Hot Rod. 964 Turbo. 79 930. 88 M3. 72 280 SEL. F80 M3 (Modded). Boring daily driven things. Other 911s sadly sold.
Old 09-18-2018, 12:44 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
Anything is possible with time and money. I would think that the quality of the installation on the existing turbo flares would effect your decision of how much you could reuse. You may have to replace most or all of the quarter panel, but if you're doing a high quality back date, I think this will be small beans compared to the rest of the scope of work. If the rest of the car is rust free, and good condition, I don't see turbo flares being much of a detractor. you can probably resell the front fenders as-is if they're nice, and replace them. Someone may also buy the rear flare clips.
Old 09-18-2018, 12:52 PM
Seth Hamilton
Thanks. I am thinking along the same lines as you, and just checking with the nay-sayers to be sure I am not a complete fool.
Old 09-18-2018, 01:27 PM
Bill Verburg's Avatar
You'll need new quarters and fenders, the radius of the arch cut on the turbo is much larger than for RS
You'd be much better off going to an RSR or RS/SC look
Bill Verburg
Old 09-18-2018, 03:49 PM
Seth Hamilton
Thank you Bill. This was exactly the information I was looking for.
Old 09-18-2018, 03:54 PM
you tube search garage time
fella turned sc flares into rs flares good place to start
Old 09-18-2018, 06:01 PM
That's me and I have an extra genuine RS Flare if you need one. Here's the link to the Youtube video for reference.
https://youtu.be/0-n4tyIfgsw
Please let me know if you need anything or have questions. Its doable like anything else, it just needs the right amount of patience, research, and practice.
Cheers,
Tom
www.ahhgaragetime.com
Old 09-19-2018, 07:40 AM
I just love it when people answer the wrong question
Bill Verburg
Old 09-19-2018, 03:45 PM
