Where can I get cadmium plated motor mount bolts for a 86 Carrera
Post say's it all.
Old 09-17-2018, 05:48 PM
Brew Master
cabmandone's Avatar
Google says you can buy one from Pelican Parts
Part #: 900-082-142-01-OEM
Nick
Old 09-17-2018, 07:30 PM
gtc gtc is offline
abides.
gtc's Avatar
You could have yours replated by Shaun.
Graham
1984 Carrera Targa
Old 09-18-2018, 08:16 AM
That bolt is zink not cad.
Old 09-18-2018, 08:49 AM
Get the Caswell Plating kit and a small crock pot at WalMart. New Zink bolts can all be turned to Yellow in your garage.
https://www.caswellplating.com/yellow-chromate.html
Derrick
Old 09-18-2018, 09:51 AM
I had the same problem. I got these bolts from Belmetric and they are yellow zinc. BTW, they are a little longer at 35mm but then you can use washers and a proper locking bolt rather than crap split washers.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 09-18-2018, 01:41 PM
I'm good with the small bolts. I need the long bolts through the center.
Old 09-18-2018, 03:12 PM
