Can you help with this Vacuum Line
The engine is out and while going through everything this cloth covered vacuum line was loose and was easily pulled out of the area where it disappears into the body.
I thought it connected to the Venturi from the Manifold for the brakes but it appears the ID is too small. Where does it go and how can it be re-connected inside the body? I did order lots of new vacuum hose from our host so I will replace it once I know where it goes. Thank You.
84 911 Cab 87 911 Targa 88 930 Cab M505 Slant Nose 62 356B Gone
Cruise control probably it’s suposed to just dump the vacuum on the cruise unit.
Bruce |
That was my 2nd thought. I know the venturi has a 4mm line to the cruise control but was confused why this line was not connected to anything.
Member 911 Anonymous
Yes, that hose connects to the top of the Cruise Control Servo and vents out the atmosphere thru the body p-side.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks for the reply!
