911 Autocross Pic - Soft suspension?
This is a picture of me driving at a recent SCCA autocross. I didn't know a 911 could lift a wheel on an autocross course. Totally stock 92 C2 with R compound tires (Kumhos). Just thought it was a cool pic. I placed third in B stock that day behind a Boxster and an E36 M3.
Drew
92 C2
Old 03-05-2003, 11:39 AM
Looks more like normal rear engine weight distribution than soft suspension to me.
88 911 (Sold)
87 951 (Sold)
Old 03-05-2003, 12:16 PM
wcballance's Avatar
Send a message via AIM to wcballance Send a message via Yahoo to wcballance
Yours isn't the only 911 I've seen lift a wheel. That picture makes me want this Sunday to come a little sooner. Our local SCCA is having their first autocross then and I'm planning on going. I hope it doesn't rain, but then again... one of my trophies (second place) is from a rainy day. Congrats on third.
I'm going to be running FP this year. My Stable Energies triangulated strut tower brace doesn't fit the definition of an allowed modification for ASP (at least the way I interpret the rules), so FP it is. Other mods like club sport motor mounts and turbo tie rods were question marks for me too. I've been told I should consider getting a ruling on my mods, but I'm comfortable running FP at least until I get a little more competitive.
Will Ballance
1971 914 1.7 w/FI intact
1982 911SC 3.2 coupe
2001 Boxster
"Was it a dream where you see yourself standing in sort of Sun God robes on a pyramid with a thousand naked women screaming and throwing little pickles at you?" -Chris Knight
Old 03-05-2003, 12:23 PM
91C2wrencher's Avatar
Ah-Ha! so thats what my car looked like! I have the same triple black C2 set -up. Only now its lowerd and has big shoes. Looks like you're having a blast! and not to worry about the wheel lift, probably one of the best photos of your car you're ever gonna get! Frame it!
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 03-05-2003, 12:27 PM
Send a message via ICQ to old_skul
That's just an indication that your tire grip has exceeded your suspension's limits. It's now time to upgrade those torsion bars or springs, and get some larger anti-sway bars.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-05-2003, 12:55 PM
Ever seen a VW lift its rear inside wheel in a tight corner? It looks like a dog doing its business at a fire hydrant, or in this case, a red AX cone.
Old 03-05-2003, 02:04 PM
jluetjen's Avatar
Looks perfectly normal to me. The rear squat is acceptable since the outside rear wheel looks nice and straight and isn't falling over. Ultimately looks like your car has a slight push when you pick up the throttle since it looks like your exiting the corner, but that could also be a function of driving style.
I wouldn't change a thing right now until your times are consistant from run to run.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-05-2003, 02:14 PM
Eric86Red911's Avatar
Yup, it's not as bad as a VW Golf hiking its inside leg. Last AX I saw two golfs do the same thing at the same corners consistently. Scary at first, then just hilarious. Lost all respect for VWs that day...
Drew- that's a great pic!
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc.
Old 03-05-2003, 02:37 PM
Isn't it better to lift a non driving, non steering tire than to lift a wheel that is trying to help steer the car like a 911's front tires do?
Old 03-05-2003, 03:18 PM
You do not have permissi
john70t's Avatar
I agree for a saftey driver, but to play the devils advocate wouldn't the steering effort and front end be lighter because of inertial transfer? I think understeer is usually faster than oversteer because momentum isn't lost in the bearings and tire scrub.
Old 03-05-2003, 03:27 PM
Jandrews's Avatar
It can happen. Here I am raising a leg trying to get back in shape after coming through a turn a little too hot!
I saved the spin, but trashed my lap time. After this, it became apparent that for AX, slower is faster!
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 03-05-2003, 03:34 PM
I'm not sure that a 911 could lift a rear tire, or at least I've never seen it before. Econoboxes are usually the ones that do that. Besides, it's not like I had a choice on which wheel to lift!
Maybe I need to get rid of my passenger next time, but my wife might not appreciate that (she's the passenger in the picture and also co-drives with me).
Old 03-05-2003, 03:42 PM
Your car seems to have the perfect setup. The only way your inside front tire could lift off is if you had enough tire grip on the outside to make it happen...awsome!
Joe
Old 03-05-2003, 03:59 PM
Bill Douglas's Avatar
Cool!
Old 03-05-2003, 04:00 PM
Automotive Writer/DP
Randy W's Avatar
Looks good Drew! Anything under about two inches of front wheel lift under hard acceleration out of a corner is normal for a well set up 911. Any more than that and you might want to tighten your rear sway bar a bit.
Will, you are right about triangulated front brace, turbo tie rods and club sport motor mounts not being allowed in ASP on an '82SC. You can run slicks in FP though!
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 03-05-2003, 04:58 PM
Senior Member
john_colasante's Avatar
I have never seen a 911 lift the rear up unless it's jumping a curb like this.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 03-05-2003, 08:18 PM
87 Carrera Backdate
Old 03-05-2003, 11:36 PM
even 4 wheels can be done
87 Carrera Backdate
Old 03-06-2003, 12:09 AM
Administrator
Jack Olsen's Avatar
Dutchie, that Martini one is awesome. That the wheels are lifting and the car is going fast enough to depress the lightweight hood is just...
...great!
Old 03-06-2003, 12:46 AM
I think it,s on the ring Jack but not sure. If you take the taxi there you will be lifted a few times Is BB2 gonna be as wide as this one ?
87 Carrera Backdate
Old 03-06-2003, 01:16 AM
