gearhead
I’m not says no you can’t convert a 923 to actuate like a 915. I am a KISS, guy. Keep it simple stupid. If I can put a 911 engine in the car and change NOTHING but the engine, that’s what I’m going to do. A 1977 was a 2.7. If it were my car I would find one and install it.
If 3.0 or 3.2 is your end goal, find a 915 gearbox and install it at the same time. A 923 gearbox is worth $500+/- more than a same or similar year 915. Makes no sense to me to chase all these clutch flywheel bearing work arounds. Again, back to kiss.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-07-2018, 12:17 PM
The guide tube is a just fit into the TOB slop shouldn’t be part of the guide....
Bruce
Old 10-07-2018, 12:30 PM
Matt,
I'm with your same thinking. I want to keep it as simple as possible.
I'm asking these questions so that I will know if I need to source a different trans.
Sounds to me like it should work without needing to do anything special.
Old 10-07-2018, 12:39 PM
gearhead
Yep. I personally like how a 2.7 revs. And the 923 has a 7:31 like a 74 had. In my eyes it makes for a nice little middie.
1974 914 Bumble Bee
2009 Outback XT
Old 10-07-2018, 12:49 PM
Matt keeping in line with the KISS method, wouldn't a 3.0 bolt the same as a 2.7?
Old 10-09-2018, 05:15 PM
Yes. Pressure plates and flywheel have the same cross section having nothing to do with
Crank bolt count
Bruce
Old 10-09-2018, 06:11 PM
