gearhead
I’m not says no you can’t convert a 923 to actuate like a 915. I am a KISS, guy. Keep it simple stupid. If I can put a 911 engine in the car and change NOTHING but the engine, that’s what I’m going to do. A 1977 was a 2.7. If it were my car I would find one and install it.
If 3.0 or 3.2 is your end goal, find a 915 gearbox and install it at the same time. A 923 gearbox is worth $500+/- more than a same or similar year 915. Makes no sense to me to chase all these clutch flywheel bearing work arounds. Again, back to kiss.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
The guide tube is a just fit into the TOB slop shouldn’t be part of the guide....
Bruce |
Matt,
I'm with your same thinking. I want to keep it as simple as possible. I'm asking these questions so that I will know if I need to source a different trans. Sounds to me like it should work without needing to do anything special. |
gearhead
Yep. I personally like how a 2.7 revs. And the 923 has a 7:31 like a 74 had. In my eyes it makes for a nice little middie.
Matt keeping in line with the KISS method, wouldn't a 3.0 bolt the same as a 2.7?
Yes. Pressure plates and flywheel have the same cross section having nothing to do with
Crank bolt count Bruce |
Thread Tools | |
Rate This Thread | |
