How to properly clean fuchs
Hi,
My fuchs are covered with some kind of haze/film. I don't t know what it is. But how should I properly clean this without damaging the surface? Unfortunately water and soap don't work... ![]() ![]()
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl |
It looks like someone has used an alloy wheel cleaner on them, I have seem that milky staining before on a friend's car after he mistakenly used something quite acidic. I would give them a good clean with soapy water and once dry give them a good coating of Vaseline. The friend's wheels eventually lost that residue/marking.
Ian |
Formerly known as Syzygy
It looks to me like someone used some sort of not very friendly spray wheel cleaner or tire dressing that may have etched the anodizing of the wheel. If that's the case, there's really not much you can do short of refinishing the wheel as it is imbedded into the metal.
I hope I'm wrong.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
How long should the vaseline stay on the rim?
Had exactly the same issue. Mine looked EXACTLY like yours.
Porsche recommends using Petroleum Jelly (Vaseline) in your glovebox manual. Rub it on, then wipe it off. Works great. Last edited by tcar; 10-08-2018 at 01:17 PM.. |
Harvey Wiedman's marching orders: nothing more than mild soap and water to clean Fuchs.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Senior Member
^+1 Al Weir agrees with the above - lukewarm water and mild soap, no detergents of any kind. Also recommended waxing after cleaning.
Vaseline will go a long way to improving the looks of your wheels. Mine were polished so the advice above (esp. waxing) is intended a preventative against the road grime and muck thrown up on the wheel.
'78 Targa in Minerva Blue |
The white oxidation of the black parts polishes away with a cutting compound.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Yes, that works on the black painted parts of the wheel. However, if you try to polish out the white on the bare metal, it'll polish through the anodization of the wheel, likely without removing the milky looking parts.
On my car, a detailer used some product that did much the same thing on a set of wheels with a year old Weidman RSR finish. That was six years ago and the marks are still plain to see, though it's not obvious to the casual observer. But it sure pisses me off every time I wash the car and see those marks.
Senior Member
By the way, if anyone is considering stripping the anodizing, go to a chromer and have them drop the wheels into their soaking tank for a few minutes. I have tried both sanding the anodizing off (holy cats!) and the chromer, and the chromer worked like a charm. Be sure to pull the wheels and check often, but the tank will strip that anodizing so cleanly you will find little need to prep before polish, mask, and semi-gloss black.
Kind of Blue
I'd give Ferex a shot on the outer edges.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Administrator
Hello - check out the link below to some excellent wheel cleaning products. I would highly recommend the Sonax cleaner. My wheels were super dirty and it worked through the grime instantly.
https://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_CARWHL-detail.htm |
Here is a before an after vaseline treatment:
1982 911 Targa, 3.0L ROW with Webers |
Kind of Blue
Ferrex is used to remove all sorts of stains and deposits on wheels. Vaseline is great for finishing, cleaning not so much.
Coram Deo
How much vaseline do you leave on the wheel? Seems like a sticky dirt magnet to me.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
I don't normally discuss religion in an online forum, but you might consider using "Honda Spray Cleaner & Polish". It is one of the best detailing products on the market. It is perfect for Fuchs because it works on anodized and painted surfaces, so no border issues.
http://a.co/d/2LtJK48 You can purchase it online or at nearly all Honda Motorcycle and Automotive Dealer parts counters. Pelican would do well to add this to their already amazing product offering. It quickly cleans up a set of Fuchs and leaves a very slick, invisible layer that helps shed dust and provides some UV protection. Porsche recommended Vaseline in the old days because this wasn't available yet...Fact. ![]() PS To the OP, I agree with others, it looks like someone used one of the wheel "cleaners" that has a PH level that is outside the range of what anodizing can survive. |
That's kind of the point. I like to use a soft cloth to apply quite a bit of Vaseline to the wheels, let them sit for a while then use another soft cloth to wipe off the excess. What Vaseline that is left on the wheels will attract brake dust and other nasty stuff. THEN the next time I clean the wheels.....and this is the important part......I take a generic spray bottle with nothing but water and a boatload of paper towels to get the old Vaseline off BEFORE trying to clean them and apply a new coating of Vaseline. You'll put a soapy cloth on the wheels with the old Vaseline still intact exactly once to realize you have a greasy gooey soapy cloth and a greasy gooey wheel to deal with and should have used the spray bottle and paper towels first! The typical spray on "Tire Dressings" will also stain your Fuchs wheels in no time. I did that exactly once. Since then I just scrub the sidewalls of the tires with a stiff brush followed by a once over with a soapy rag and rinse immediately and do without any kind of "dressing". Last edited by SCadaddle; 10-09-2018 at 08:43 AM.. |
I dont use a ton. I apply it then buff it off with a clean cloth. I dont think you can use too much. Just makes the wiping of it away a little more difficult.
